Hola,
A few months ago I made a post about looking for a tower fall arrest system consisting of a vertical cable that sets off from the vertical tower leg with a slider that connects to your harness. If you fall, the slider locks up and stops the fall. They are now required on all commercial towers; and for good reason. Hams can still legally get away without using them...
These systems can be very expensive. I've seen them for over $1,000 for the complete installation kit on 100' towers.
I was able to find the two main components rather cheaply, (the slider and cable) and the slider is still quality stainless steel, OSHA rated. I also found a vendor who will supply the 5/16" galvanized aircraft cable for only 25 cents a foot... at least for the 700' I ordered. The only things missing are the brackets that hold the cable offset from the top and bottom of the tower. I used two 9" long, 4"X 4" steel angle stock that are drilled to accept two stainless steel U-bolts each, to fasten them to the tower leg. They are drilled to accept the cable using little cable u-bolt clamps to hold the looped cable at each end.
Here's the website for the safety slider. It costs $132. It disconnects so can be used on multiple towers.
http://www.westernsafety.com/msaroseproducts/msafallprotec10.htmlOr call: 206-264-0808 to order it. Part # SFPLS350-020 (Sure Climb Slider)
Here's the email adr for the 5/16" aircraft cable. It must be 5/16" diameter.
shay@starrrproducts.com (Scott)
I plan to install a system for each of five towers. Total cost: only $382 plus some scrap steel angle and cable fasteners. For one tower that's 100' tall, you could get away for well under $200. No reason not to have one, caw mawn.
Please post here if you decide to install one for your tower. I'd be curious.
73 and safe climbing this season,
