How do I go about inserting a picture next to my postings? I have a pic of my ARC-39 Transceiver that I am trying to enter into my profile to "spruce up" my postings.
You might check the "Using the BBS section for info on avatars but briefly:
Go to "Forum Profile Information". You have a choice of several options
Personalized Picture:
Do Nothing
I have my own pic:
Specify your own avatar by URL. (ex:
http://www.mypage.com/mypic.gif)
I will upload my own picture:
When done, click on change profile.
The key is this: "The largest picture size allowed is 100 wide x 175 high. The program is set up to refuse the avatar if larger than those dimensions." Follow what I said above. Then double click on "Browse" and it should point to your C: drive. Change directories to where your proposed new avatar resides. Double click it, and the entire link to it should appear in the Browse field. Click "change profile" and if it doesn't exceed the size requirements, it should appear as your new avatar. If you don't see it, even after you refresh the screen, most likely it's too big.
You could also go to the bottom when creating or editing a post, click Additional Options, and upload a picture to your post. Here's one I pulled from somewhere off the web, saved it to my hard drive, and then uploaded it with the "Additional Options". Note, you can't preview this picture in the text, until you post it.
