Has anyone had any experioecne with those screw in LED bulbs that are slowly becoming popular. These are not CFL types. Instead they use actual LED's encased within the bulbs housing. Apparently they use those ultra bright "near white" LED's.
I wonder if that is the same kind of LED used in LED flashlights. After going through 3 of those things I refuse to buy another. Each one of mine worked great for a few weeks, then one by one, the LED's went dead. Never was sure if it was the LED itself or the connection that went bad. I tried replacing batteries but that didn't affect anything. One light had 6 LED's and I threw it in the trash when the 3rd LED died. They are supposed to last for years and use up batteries at a fraction of the rate of incandescent bulbs. But if the LED's start dying in three separate lights within a few weeks, something is wrong with the design.
I notice that a lot of car brake lights now use a cluster of red LED's instead of an incandescent bulb and beaded plastic lens.
That is strange. The LED's should last a long time. I wonder what could be contributing to shorten the life of those LED's by that much. Could it be that the LED's they use are rated for a voltage lower that what the flashlight batteries are supplying ?? It'sreally strange because they "should" be quite durable and last for a long time.
I have one of those LED keychain flash lights. It uses a single high intensite "white" LED. It runs on 2 3 volt lithium wafer cells (i.e. 6 volts). It gives off a rather intense bluish white (mercury vapour - like) light. The intensite is bright enough to hurt the eyes of I look sirectly at it. I have had it for years and have had no problem with the LED. Likewise other high intensite LED devices (including laser pointers) have never given me problems.
Hey, anyone seen those green pocket sized laser pointers ?? Those things seem really cool, I like the idea that the laser beam is green as opposed to common red. Being that the eye response more readilly to the green wavelength it appears much brighter and much more visible to the human eye. I'dlove to get one but I cannot justify paying over 100 bucks for a pocket laser that I don;t really need to begin with. Should they come down in price though I wouldn't mind getting one.
