December 15, 2025, 11:57:06 PM *
Author Topic: is the 6293 a sub for the 6146?  (Read 3841 times)
KR4WI
« on: February 11, 2006, 10:19:27 PM »
I just picked up a viking ll today. When I looked into it and pulled the final tube it had jan crc-6293 in it, and could not find a number for the other final, is this a substitude for the 6146 tube??       Matthew KR4WI
« Reply #1 on: February 12, 2006, 02:43:42 AM »
Matt,
        A 6293 is basically a pulse rated 6146 with a slightly higher dissapation rating. If you use them in pairs they make an excellent sub for a 6146. (dont use 1 6293 and 1 6146 as a pair) I have personally used them in several transmitters in the past. Best of all not many people know what they are, so they can usually be found cheap at hamfests!
KR4WI
« Reply #2 on: February 13, 2006, 09:31:38 AM »
Frank:  Thanks for the reply, they was only one in the final. So I pulled both and put 6146 in, seem to be loading ok. I will ck it more this morn. Matthew
Page created in 0.043 seconds with 17 queries.
