March 09, 2026, 01:38:03 AM *
Author Topic: Designing a Clean Linear Amplifier with RF Negative Feedback - Opinions Wanted  (Read 23533 times)
« Reply #25 on: December 16, 2005, 03:55:50 PM »
Another good response below....
The 4CX-350 is very common comapred to the 'J' model.  Hope he's correct.
wc6w@juno.com wrote:
> Hi Tom,
>    That '5106 is probably for Cable TV use and likely cuts off around 40 MHz (on the low end!).
>    If I recall correctly, some of the general purpose units that go down to a MHz use numbers from CA28XX group.  They come in both single ended and push-pull versions.
CA2820 and 2830 are good ones, 0.5-1W capability and only a couple of
power line decoupling caps needed. Motorola equilvalents are MHW590 and
592 - these replaced the TRW parts after Mot bought TRW. Many other
CA28** or MHW parts will also suit, but some need external chokes or
transformers. Beware the gain - around 30dB. If you're running about
1-200mW out for linearity, it means only -10dBm in (ideal if you build
your own exciter). If you're going to do that, you could consider going
the whole hog and incorporate polar or cartesian loop feedback.
>    I've seen a few of the 350J's for sale on the web over the years.  I don't believe the demand is very high for those as they have a 26V heater and as such can't be dropped into a 4CX250B socket.  There is also the 4CX600J/JA/JB.
I'd bet that the 'FJ is barely different from a std '350 - just tested
for linearity under class A. They might be a few dB better than 'any
old' '350, but I'd be surprised if the difference was more than a few dB
- not 10 or more.
« Reply #26 on: December 16, 2005, 05:10:20 PM »
Yet another good idea.  Your own shack "spectrum analyzer":
Dave/Ape you were axing about this the other day...
Hi Tom,
You do have a spectrum analyzer in your shack! Your receiver.
Modulate the transmitter with 2 tones and tune across with your cw
filter on another receiver. Note the level of one of the tones on the S
meter. Then tune to the 3rd order product and note the level difference.
Same thing a spectrum analyzer does.
If you want to get real accurate put a step attenuator in front of the
receiver so you don't depend on S meter calibration.
Now you will have a base to work from.
Gary  K4FMX
Page created in 0.046 seconds with 17 queries.
