April 28, 2024, 03:56:44 PM *
Author Topic: The Heil Hum ?  (Read 3607 times)
« on: December 07, 2005, 08:43:47 AM »
I was curious after reading this exchange about hum on a Heil microphone.
Apparently the element is not shielded ?  Odd for a mic intended to be in an RF environment.
--- W3CRR  wrote:
> I'm having tons o' fun with my "new Collins 32V-2,
> BUT, I've got a hum
> problem. According to several listeners, my Heil
> Classic microphone --
> while sounding great otherwise -- may be picking up
> EMI from the nearby
> transmitter iron.  The mike has no internal
> humbucking coil.
> Has anyone else experienced this problem with
> dynamic mikes and heavy
> iron?  If so, how did you solve it, please?
> Many thanks and 73,
> Craig
> W3CRR
Message: 2
Date: Mon, 5 Dec 2005 10:42:16 -0800 (PST)
Subject: Re: [AMRadio] mike hu-m-m-m-m problem
To: Discussion of AM Radio <amradio@mailman.qth.net>
Craig,
   If the problem is the mic element picking up stray
hum, then moving the mic around will vary your
symptoms. Do you see that?
If so, you can use the mic to zero in on the source of
magnetic flux. Steel, or preferably Mu-metal (the
stuff around oscilloscope CRT's) can offer shielding
from stray flux.
   Here is a silly thought; remember an old photo in
the ARRL handbook where a car distributor cap was
shielded with a large tin can, and then copper braid
was added to shield each plug whire, and was soldered
to the same tin can? Doing something similar to your
prize mic might help, or go back to an Astatic D-104.
That crystal element is immune to this problem. :-)
   More seriously, maybe you can find the source of
flux, and eliminate it at it's source. For example
with my QRO 20A I had hum in the nulled carrier (120
hz) that was much worse after adding a filter choke
(open frame)to the power supply. The flux from the
choke was coupling through the metal chassis, and into
the two modulation transformers. The fix was to
replace the choke with another that was enclosed in a
steel case. Problem was solved. I could have also
tried to change component orientation, but limited
real estate to do so did not allow this option. I
still had some hum in the carrier null but this was 60
hertz. I added a hum neutralizing circuit to buck out
the hum in the proper phase, and magnitude. In the end
with a 6.3 vCT  filament circuit, I used 20 ohms to
inject current into the balanced modulator diode
support bracket. The carrier null was now without a
measurable 60 hz component.
 I hope you resolve the huuummmm issue with that nice
Heil microphone.
Jim Candela
Date: Mon, 05 Dec 2005 15:00:48 -0500
Many thanks for your very detailed and useful reply, Jim.  I was sorta
hoping this could be dealt with with a wad of aluminum foil, but....
I just read a broadcast engineering publication review of a couple of
Heil mikes. Sonic quality and "value for money" ratings were high --
but
the reviewer did register a complaint that these Heil models did not
incorporate a hum bucking coil and were, consequently, prone to noise
pickup from nearby power supplies. Simply moving the mike far enough
away from the hum source cured the problem, but that's not always
feasible.
I do have a roll of 4-inch wide Mu metal, so I could fashion shielding,
if need be and I'll look into the more complex solutions you recalled
if
I must.
However, I did, in fact, buy a good old D-104 from an eBayer this
morning just in case all else fails :-) .  Every vintage shack should
display one anyway.
Craig
W3CRR
Paul, K2ORC
« Reply #1 on: December 07, 2005, 09:16:16 AM »
Well, it's interesting that Radio World's review of the PR40, Heil's broadcast mic, gave a minus for the mic's lack of a humbucking coil.  Evidently W3CRR's isn't an isolated experience.  The RW reviewer noted that the PR40 element picked up EMI hash from a nearby Aphex 1100's power supply and a CRT monitor whereas the RE27-- which the Heil ads show to be one of the mics KMOX put in a box destined for eBay --did not.
Go Duke![/b]
« Reply #2 on: December 07, 2005, 04:05:33 PM »
That was the problem with my old Electro-voice ribbon mike.  Hum pickup from nearby power supplies was almost as loud as the microphone's audio pickup.  I have had similar problems with dynamic mics.
