Hi Chris,
Yes, at one time Lich/ETP, Dino/KNX and I did a lot of comparisons and tests with mobile antennas on 75M.
Most of us had built homebrew versions of Bugcatchers and tried many other beefed up/ homebrew mobile versions.
You will find on 75M that the Hamstick is down about 6db from a full blown Bugcatcher. And, a simple 9' whip with modest B&W coil is within 2-3 db of the BugCatcher.
You can only do so much with any vertical whip portion of the mobile antenna since the vehicle's ground is the limiting and lossy part of the equation. I even tried using a full sized 60' vertical next to the car and saw little or no improvement that I cud measure against the full 11' bugcatcher. This is because instead of a nice 10 ohms or less ground radial system to work against, a car's ground plane might present 100++ ohms or who knows? Remember that a mobile whip on 75M has an input impedance down in the single digit ohms. So, a 9 ohm antenna into even a great 9 ohm ground system is a 3db loss already.
I once compared my vehicle on 75M against a full sized dipole at 60'... A/B swirtched them on 75M. The dipole was always 15-20db louder. That is the hit you take mobile. This was late afternoon when the mobile vertical works the best and the lower angle is an advantage. Use a Hamstick and it will become 21-26db down.
But, 6db is not such a big deal compared to the Bugcatcher on 75M. ie, You can still work all the same stations, but it will just seem like you are running 1/4 the power out and the other station is running 1/4 the power too...
On the higher bands the vehicle's ground plane is more efficient. You will find the various whips get closer in performance since they become more "full sized".. After all, a 9' whip is a full 1/4 whip on 10M, so the various shortie whips tend to catch up to the "bugcatcher" types. Guys with tractor trailers do outstanding on 40-10M cuz of the huge ground plane. A low angle from the vertical on the higher bands is a natural too.
The ultimate 75M mobile setup was when Warren/K2ORS pulled 60' wire radials behind his car going down the highway. It worked great until cars behind him started breaking off the wires...
