Avery Labels and Word work FB OM for individual labels.
An alternate approach is to get a single piece of clear contact paper for inkjet printers and do the entire face as one label; this way you can have the text, radials lines etc done as a single sheet. This works well for small projects, but you'd not want to do it for the face of an entire radio of large size.
I'd use Microsoft PowerPoint if I was going to go this route. I've found that Word's drawing abilities are inferior to those of PowerPoint. YMMV.
Vely, bery interesting, Mark. I like the idea.
I have a few new projects coming up that I plan to take my time and do right over the winter. A new PDM 4X1 rig and maybe a bunch of monoband linears so I don't have to row around to each band anymore...
So, this clear contact paper... what is this, like a clear plasdick sheet with an adhesive back? Not sure if I've noticed it before on the store shelves for ink jet printers, but never looked.. I imagine you could also do small areas of a large panel and stick it on after cutting it into pieces.
Does it have a piece of wax paper to protect the sticky back until use? And how well does the standard black ink jet ink stick to the plasdick?
Thanks, OM.
