December 08, 2025, 02:21:42 AM *
Author Topic: Plastic Capacitors Inc oil filled HV capacitors  (Read 519 times)
John K5PRO
« on: July 11, 2025, 01:20:53 AM »
Instead of getting a series string of big electrolytics balanced with equalizing resistors and waiting for one to go bang, you can also use classic oil filled rectangular capacitors, as found in many pre-1970s amplifiers. They were also found in most broadcast transmitters with tubes. Like new ones are rare these days. I have some new and used, and they don't fail unless a terminal insulators get broken off causing oil leak. All of these are non PCB. Photos available on request.
7 pcs LK50-306Y  30uf 5 kV  7-3/8 inches L x 5-5/8 W x 8 H + 1-1/4 for the insulated threaded posts.      $30
6 pcs LK40-156  15uf 4 kV  4-5/8 inches L x 3-3/4 W x 8-1/2 H + 1-1/4 for the insulated threaded posts.   $20
2 pcs LK50-605Y  6uf 5 kV  4-5/8 inches L x 3-3/4 W x 4=3/4 H + 1-1/4 for the insulated threaded posts.   (use in modulator as a coupling cap) $10
Shipping to be added from New Mexico, UPS or FEDEX
John
K5PRO
Page created in 0.042 seconds with 17 queries.
