May 31, 2026, 02:01:13 AM *
Author Topic: 811A: Center tapped primary?  (Read 1535 times)
KW6T
« on: February 06, 2025, 05:14:48 PM »
Good day.
A quick question.  For my Johnson project, I am running a pair of 811A's in the modulator as the manufacturer intended.  The available transformer's 6.3 volt winding lacks a center tap.  Is it possible to run these tubes without a filament center tap?   Otherwise, another $350.00 transformer order will be necessary.
Russ
Russ
"Cheap" is rarely the least expensive.
K8DI
« Reply #1 on: February 06, 2025, 06:16:27 PM »
I was up this same creek a while back and a few folks here reminded me I don’t need the center tap to carry more than the plate current. A one amp 6.3v ct transformer in parallel with the one you have now will provide the reference. DON’T connect the primary to power. It’s really a couple opposing inductors to ground. Added bonus: there’s 120v on the primary. Induced there by the filament voltage, it can only provide a small current…just enough for some grid bias! Extra added bonus— it doesn’t have to be a 6.3v transformer. Try a 12.6vct unit. It’s still two inductors to ground, although you’d only get 60v on the primary to swipe bias voltage from..
Ed
MikeKE0ZUinkcmo
« Reply #2 on: February 06, 2025, 06:48:19 PM »
I agree with Ed's recommendation for a 1 amp 6 volt transformer.    I did the same in my DENTRON years ago for the same AC hum cure.  Lots cheaper than the $320 unit you mentioned.
Mike KE0ZU
KW6T
« Reply #3 on: February 06, 2025, 11:29:46 PM »
Mike, Ed,
Many thanks!
Russ
Russ
