April 12, 2026, 09:23:55 AM *
Author Topic: Duty cycle adjustment for 40 meters  (Read 8097 times)
W9BHI
« on: January 05, 2025, 11:30:48 AM »
Anyone have a circuit for changing the duty cycle of the square wave output on the driver on 40 meters? The one Steve (QIX) uses won't work at 7Mhz.
vk3alk
« Reply #1 on: January 05, 2025, 05:08:35 PM »
Hi Don
In the past I found Steve's circuit worked well on 160/80M but didn't have the full range on 40M using the 11N90 FETs....
When I built Nigels 40M VMCD using the CREE FETs it worked well and was able to stretch the Duty Cycle close to 50% which it seemed to like....
Also in the past have applied variable DC bias to the IXDD input.....about 2 -3 volts no more and that changed the DC....but cannot remember whether this was tested on 40M though....
Hope this helps...
Wayne
« Reply #2 on: January 09, 2025, 08:59:21 PM »
Here's a circuit. You may have to tweak C1 and C2.
* Pulse Width and Timing Circuit.pdf (23.13 KB - downloaded 307 times.)
W9BHI
« Reply #3 on: January 11, 2025, 09:48:31 AM »
Will this circuit work at 7 Mhz?
« Reply #4 on: January 13, 2025, 05:43:09 PM »
Switching frequency of 74ACT74 is up to 210MHz, so yes,
https://www.ti.com/lit/ds/symlink/sn74act74.pdf?ts=1736762340660&ref_url=https%253A%252F%252Fwww.mouser.co.uk%252F
« Reply #5 on: February 08, 2025, 06:46:47 PM »
Hmmmmmmm...  I use my circuit on 40 meters, and it works quite well.
It's been a while since I've had to adjust it, and I don't remember if I had to make any circuit value adjustments for 40.  I don't recall making any, but if I did, they were very minor.
W9BHI
« Reply #6 on: May 05, 2025, 10:30:03 AM »
Steve, Here is the circuit that I use. It is the same as yours with a few embellishments. The 160/80 duty cycle adjustment works but the 40 doesn't. Here is the schematic.
« Reply #7 on: August 05, 2025, 08:24:04 AM »
I will have to look at my 40 meter A to D converter and see what I did :-)
It definitely works, and I use it all the time on 40 meters.  But, I think I had to make some minor modifications to the circuit.
Also, not all components are created equally.  I have found that variations in the input inverter IC can cause anomalies, particularly on 40 meters.  I think I worked around these component issues, but I do have to go look at the converter and see exactly what I did.
Interestingly, I get 300 watts of carrier output using 4 FQA11N90 on 40 meters.  Running 45V @ 7.7 amperes (at carrier).
