February 17, 2026, 06:37:50 AM *
Author Topic: Henry 2000d generator  (Read 16436 times)
Detroit47
« on: September 02, 2024, 04:01:28 PM »
I recently acquired a Henry 2000d 27mhz generator. I have no documentation I am looking for a schematic and parts list. The original manual would be great.
Johnathan N8QPC
W1ITT
« Reply #1 on: September 02, 2024, 05:30:10 PM »
https://www.rfparts.com/radioamp-service/radioampparts-henryradio/sm1000d.html
Looks like RF Parts will sell you a reprint of the manual..
73 de Norm W1ITT
Detroit47
« Reply #2 on: September 02, 2024, 11:11:41 PM »
I would prefer a free PDF. I know there is one around somewhere, but I will pay if I have to. Thanks for the information. I did a Google search I am surprised that didn't turn up.
Johnathan N8QPC
W1ITT
« Reply #3 on: September 03, 2024, 08:35:59 AM »
It's been my experience that DuckduckGo searches deeper than GooGoo which seems to have odd agendas.
73 de Norm W1ITT
« Reply #4 on: September 04, 2024, 08:12:23 PM »
IIRC, those were built similarly to the Henry amateur band amps of the era. Of course there was no bandswitch. I had a 13 MHz Henry in year past (just the amp, no power supply). That parr of the schematic is pretty easy to figure out. I ended up parting it out.
Detroit47
« Reply #5 on: September 04, 2024, 08:55:50 PM »
I have the complete unit and it is operational. I had a discussion with a fellow at Henry and he is providing me with what I wanted. I could have just winged it but this was easier. Plus it was cheaper than RF parts. I am the stereotypical cheap ham. I'm not rich folk like y'all.
Johnathan N8QPC
« Reply #6 on: September 07, 2024, 08:28:18 AM »
Johnathan N8QPC
I'm a little faster than Henry.  Smiley  Was out of town / on the road and had to get the VPN working to get access to the files back home.  Here ya go, it's a crappy copy, but it works.  I have some other pages I can provide that are better, but all around the same.
Enjoy.  Made a living off these things for awhile.
WP2ASS / ex KD6VXI
* Henry2kWRfGen.pdf (2776.08 KB - downloaded 204 times.)
« Reply #7 on: September 07, 2024, 10:35:12 AM »
I have some other generator schematics and service manuals as well..  Almost all based on the Henry line and renamed, up to 5kw (with the difference between the 3000 and 5000 being a change from 4-250 driver to 4-400 and the 5kw has a pair of plate xformers vs a single for the 2000 and 3000.
The 2000 runs a 4-65 driver or a 12 volt 2 transistor driver.  The 3000 runs a pair of 28 volt devices, but at 14 volts.  The 5000 runs the same driver at 28 volts.
They used Varian and MRF devices.  Usually MRF devices are later builds.
Plate modulation the driver or even scream modulation a 4-400 swapped in for the 4-250 makes a wonderful legal limit self contained rack mnt xmitter.
Word to the wise.  If the choke isn't shorted, immediately lift both the choke and plate xformer from the chassis.  Those ECA iron just suck!  They very easily short.
I usually yank the choke, change to a different cap and make it a fwb cap input.  That will give 6kv on the plate and you can make legal limit with a Ranger.  A full Viking or valiant will be 3db or better above legal limit.
I like these.
WP2ASS / ex KD6VXI
Detroit47
« Reply #8 on: September 07, 2024, 12:21:13 PM »
Thanks Shane
I am  not quite sure of my plan for this yet. Th 3000 is worth more.than what I paid for it.
 Johnathan N8QPC
« Reply #9 on: September 07, 2024, 11:53:42 PM »
Hi John,
Is your Henry 3ph or single phase? Wink
Detroit47
« Reply #10 on: September 08, 2024, 10:21:42 AM »
It is single phase. The RF deck was designed by Rube Goldberg. I guess it was made to accommodate a changing load.
Johnathan N8QPC
« Reply #11 on: September 08, 2024, 03:12:59 PM »
Ah, that is prolly good in your case.
I'm always looking for 3ph iron in that power range.
Detroit47
« Reply #12 on: September 08, 2024, 03:34:09 PM »
I wish I.had known that I had a  Collins amplifer / trasmitter single 4cx5000..
3 phasee 220. I traded it off I couldn't use it.
Johnathan N8QPC
« Reply #13 on: September 09, 2024, 07:58:38 PM »
Johnathan N8QPC
They where almost always designed by Charlie Asimoto who later went on to found ASI (Amp Systems Incorporated).   Charlie designed most of the high power Henry stuff since the mid 70s.  Smart guy.
I've worked on plenty of his stuff to realize smart didn't always translate to working.  He built a bunch of 10ks amps for uncle Sam back in Desert storm days.
None worked upon delivery.
And yes on the changing load.  Tons where for plasma generation so they did have load changes depending on application.
WP2ASS / ex KD6VXI
« Reply #14 on: September 09, 2024, 11:46:54 PM »
Yep, 3ph 'smaller' iron, since our service is 200A 277/480 (on a residential rate meter)with a 45kVA dry step-down to 120/208.
3ph supplies are so easy to filter, FW gives you a little 360Hz ripple. 2Hy & 2uF works pretty well, 4 & 4 is almost pure DC, and the source impedance is down in single digits.
And they take up a lot less room than 1ph supplies.  Lighter, too...less iron.
D
KF7WWW
« Reply #15 on: September 12, 2024, 10:13:06 AM »
I’ve converted several of them also. They get the job done.
« Reply #16 on: September 22, 2024, 12:43:30 AM »
There is one 3 ph iron here, from a 3cx3000 Henry. come and get it!!
« Reply #17 on: September 22, 2024, 10:11:56 AM »
Patrick, can you post a pic for me?
What better reason for a road trip than iron? Cheesy
« Reply #18 on: October 20, 2024, 12:49:23 AM »
I will be where the item is tomorrow. Hopefully my senior moment does not occur!
« Reply #19 on: November 08, 2024, 09:32:33 PM »
That power supply plate is behind a stack of stuff 4 FT wide 4FT tall and and 2 FT deep Next time my helper is here I'll get pics.
The comment about the rube goldberg RF deck, well they were smart to save money on caps by making their own wierd ones for that small range. The filament voltage monitoring seemed odd - -rectifying to DC and sending it out the 11-pin connector. - but I guess it's so they could resort to a multimeter. Gauche but very practical.
