December 05, 2025, 01:57:28 AM *
Author Topic: FT-102 Overshoot Fix - by Mal, NC4L  (Read 26276 times)
« on: June 12, 2005, 04:48:36 PM »
No more key down overshoot!
http://www.amwindow.org/tech/htm/ft102overshoot/ft102overshoot1.htm
KI4NR
« Reply #1 on: April 30, 2008, 06:49:28 PM »
Although I have the ultimate respect for Mal NC4L and his overshoot mod does work. There is a simpler way to stop the overshoot without all the complication of cutting the AF board and 8 Volt regulator and you don't even have to pull a board. If you look at the wiring schematic you will know notice the mode switch segment S-1F goes to the counter board J01/P54. This segment of the mode switch is responsible for the changing mode indictor on the display. It also has a fix 8 volts powering it which is what we need for the AM modulator.
My mod is this simple. Go to the top of the counter board Connect a wire to the anode of D-06 that is connected AM-N on the counter schematic, run this wire down to the AM unit. Cut the AM TX8V wire from plug P60 Pin 1  (leaving enough to solder the new wire to the plug) and connect to your new wire from D-06 , shrink tube all connections and your done. When you go to AM the mode switch S-1F now power's the AM modulator with a fixed (AM only both TX&RX) 8 volts and the overshoot is gone. The voltage disappears in all other modes but AM ........Simple , effective and easy and no regulator needed, Just a piece of wire and a understanding of the radio.
73 john KI4NR
LPC Wireless
http://www.qsl.net/ki4nr/
« Reply #2 on: July 31, 2008, 03:03:17 PM »
Link in first post broken.
New link:
« Reply #3 on: July 31, 2008, 03:20:23 PM »
Nice! I like it.
73 john KI4NR
LPC Wireless
« Reply #4 on: July 31, 2008, 07:04:26 PM »
Someone oughta have a word with the webmaster over there at the amwindow Roll Eyes
« Reply #5 on: July 31, 2008, 07:54:48 PM »
Yea, he sux.
Nice catch.
Page created in 0.108 seconds with 17 queries.
