March 12, 2026, 02:16:51 AM *
Author Topic: Viking 500  (Read 2355 times)
KB5MD
« on: August 09, 2024, 06:47:32 PM »
My Viking 500 let the smoke out of the high voltage filter choke.  I am considering installing a replacement in the center tap of the plate transformer secondary rather than in the b+ hv line as originally installed. This method was used by Hallicrafters in the HT 33 amp.  Has anyone else done this? It removes the hv off the choke.
w7fox
« Reply #1 on: August 10, 2024, 09:32:58 AM »
I wouldn't do it.  It puts high voltage ripple on the center tap of the plate transformer, which may not have sufficient insulation.  Some power transformers have a warning on the label to keep the center tap within one volt of ground.
« Reply #2 on: August 10, 2024, 11:14:46 AM »
That choke is a swinging choke. Replacing it with a fixed choke might cause diminished voltage regulation, and ripple issues. As it is, the 811A's are operating beyond specifications. I'd try to purchase a new one from a Hammond distributor. Save up some food stamps though!
I attached the datasheet from Peter Dahl.
https://www.hammfg.com/electronics/transformers/classic/pwdahl
Wd5JKO
* PWDI13036.pdf (143.52 KB - downloaded 125 times.)
