June 16, 2024, 01:48:24 PM *
Author Topic: 40 meter Class D  (Read 4485 times)
WO1U
« on: March 10, 2024, 12:11:15 PM »
Hi,
Attached is a PDF design for a 1/2 Bridge VMCD amplifier with test data. I hope someone finds it useful.
Mike
* Halfbridge_Amp.pdf (4147.22 KB - downloaded 144 times.)
kb3ouk
The Voice of Fulton County
« Reply #1 on: March 12, 2024, 09:17:06 PM »
What, if any, components are frequency dependent? I'm assuming C1 and L1 and L3, C5, and C6 form input and output tuned circuits. Looks like a very simple design to put on the air, especially since it would be nice to have a rig that can put out some power on 40 without the heat for summer time use.
WO1U
« Reply #2 on: March 24, 2024, 04:48:43 PM »
Hi Shelby,
The band specific components are L1, C1, L3, C6.  L1C1 is for VSWR reduction, and L3C6 are tuned impedance matching. You should be able to scale this to lower bands using values with the same reactance on the desired band. I doubt you could get higher than 40m with these devices.
Hope this helps,
Mike
