January 24, 2025, 02:20:14 AM *
Author Topic: How to know when to stop working on the radio..  (Read 2052 times)
K8DI
« on: February 02, 2024, 08:53:44 AM »
So..  I've been back at my RCA, trying to get a modification finished in time for the kickoff of tonight's AM Rally.  When working with a tube transmitter with a pi output network, there’s an easy way to pre-tune the network if you have any sort of VNA, and know the plate load.  With the power off. you clip in an equivalent resistor across the plate and ground, then feed the output with your VNA. Tune for 50 ohms, and when you power it up, it will be close.
The important thing to remember is to remove the resistor when you’re done.
1500v/4k=375mA
375mA*1500v=562w.  1/4w metal film lightbulb...
(this was last night...time to call it quits)
« Reply #1 on: February 02, 2024, 09:42:10 AM »
Lol.  I've done that.
With 130 uF at 6.2 kv and a 1.7k resistor!
6200/1700 = 3.65A
3.65A x 6.2kv = 22.6kw!
Thats why I started using 1/8 watt fuses for those!  Lol
Input too.  Always nice to tune the input with the vna, then throw 3 to 5 hundred watts of drive into the tube.  Nice smell that will make you change your drawers
WP2ASS / ex KD6VXI
w9jsw
Two shots of Whisky
« Reply #2 on: February 02, 2024, 10:49:59 AM »
BTDT
Hooked up the test rig but forgot to connect the HV. It was tucked against the chassis.
Glitch resistor went off like an M-80. Blew a breaker as it should have. Should not have exploded the glitch.
After careful study, I had too many strands on the K1JJ HV fuse (RG-8 strands from the braid) and a too small glitch R. Was 25 ohms at 20W. According to Eimac, should be at least 50 ohms and 50-100W.
Time to take a break and change the whitey-tightys.
John
w8khk
« Reply #3 on: February 02, 2024, 12:34:47 PM »
At least, be thankful you remembered to remove the VNA from the RF output!  Easier to view a zorched resistor with humor!
When I am working on any of the high-voltage equipment, if the task requires several steps of disconnection or disassembly, as I proceed, I create a simple checklist, starting at the bottom of the page, working upward, listing each part that was disturbed.  Then when I am ready to restore it to test status, I start at the top, and make sure I have left nothing in an unsafe condition.
It may be a sign of getting old, as I did not do this years ago.  But if a checklist works for licensed pilots, both young and older, it can't be all bad.  If I am too tired to go to the trouble of keeping the safety list, it is time to do something else!
« Reply #4 on: February 03, 2024, 09:38:22 AM »
This isn't being old, it is experience! Or as Harvey Penick referred to it as 'well-seasoned!' Remember what George Santayana said: "Those who fail to remember the past are condemned to repeat it!"
