Need a quick check on D104 wiring. It is a non-amplified
G stand. I am using a TRS plug with a Heathkit DX60B with a PTT mod. Tip is the relay (Red), collar is audio in (Clear), and longer section is ground (Black/Shield). There are only 3 wires in the G stand, black, brown and green. CW works fine but I can't get the mic to work though it does key up the rig and I get resisting plate current. I verified the wiring with continuity checks. The capacitor was recommended to help eliminate hum on the audio.
I can't get any modulation with the mic and before I tear into the rig thought I would verify the mic wiring.
Bill KO4NR
