December 03, 2023, 06:05:31 AM *
Author Topic: Astatic D-104 with 1 volt on Mic  (Read 878 times)
n8fvj
« on: August 26, 2023, 09:18:03 PM »
The unamplified D-104 as used on a Johnson Ranger sees 1 volt on the mic from 12AX7 grid thru a 4.7K resistor. Does the D-104 element have a blocking capacitor installed? If not does not will 1 volt affect the mic?
I can find 100s of amplified D-104 schematics but not one unamplified schematic.
n8fvj
« Reply #1 on: August 27, 2023, 08:57:44 AM »
No replies. I will install a coupling cap in microphone base to remove that 1 volt.
« Reply #2 on: August 27, 2023, 12:40:13 PM »
My unamped d10-4 has a schematic inside the bottom plate... not at home, so I can't give yew a definitive answer.
KLC
« Reply #3 on: August 27, 2023, 02:48:17 PM »
Pin 2 of the 12AX7 should have zero volts on it from original design. See the partial schematic.
« Reply #4 on: August 27, 2023, 03:06:34 PM »
UNAMPLIFIED ASTATIC D-104 SCHEMATIC
Easy to find - see below
The microphone cartridge does not have any series "blocking-type  capacitor" in the lead.
n8fvj
« Reply #5 on: August 27, 2023, 03:50:10 PM »
Thanks Pete.
« Reply #6 on: August 27, 2023, 07:54:20 PM »
No need to if you understand the schematics posted here in post #12 and 16  and following:
http://amfone.net/Amforum/index.php?topic=48171.0
What is your grid resistance? The higher the grid resistance the greater the grid-leak voltage; basic tube theory.
