May 15, 2024, 11:08:55 AM *
Author Topic: Removing the shaft fitting from a collins PTO  (Read 705 times)
N4LTA
« on: August 16, 2023, 11:19:30 AM »
I have a 51S Collins PTO and am trying to remove the fitting from the 1/8" shaft. I have a set of Bristol spline and hex wrenches, but it appears someone has stripped the retaining set screw.
Any idea how to remove it?
K8DI
« Reply #1 on: August 17, 2023, 08:49:45 AM »
Do you need the fitting?
If not, grind/file/cut/Dremel it until you can pry it off…  I’d start with a cutoff wheel across the set screw in hopes to use the slot I cut with a flat blade to loosen it before I have to grind the whole thing away.
Ed
