...The tube operating parameters are from the tube data sheets when operated at the approximate 500 volts plate. I am not sure of the resting plate current when a tube is operated at lower than specified screen voltage (not shown in tube data) and -28 volts bias. Best to simply avoid using those tubes.
The bottom of the 1614 data sheet says this: "Curves under type 807 apply to the 1614 within its maximum ratings."
So you should be able to determine 1614's Sg, Ip at VP, Vcg, etc. from the 807 curves.
