INCANDESCENT LAMP BAN RULES
May 28, 2023, 05:21:22 AM *
Author Topic: INCANDESCENT LAMP BAN RULES  (Read 637 times)
« on: May 20, 2023, 10:19:04 AM »
There is a policy implemented with rigid enforcement regarding incandescent bulbs.
THIS POLICY WILL NOT EFFECT BULBS USED IN HAM RADIO!!
(except as a dummy load)
Info:
"General service lamps do not include:
Appliance lamps
Black light lamps
Bug lamps
Colored lamps
G shape lamps with a diameter of 5 inches or more as defined in ANSI C79.1– 2002
General service fluorescent lamps
High intensity discharge lamps
Infrared lamps
J, JC, JCD, JCS, JCV, JCX, JD, JS, and JT shape lamps that do not have Edison screw bases
Lamps that have a wedge base or prefocus base
Left-hand thread lamps
Marine lamps
Marine signal service lamps
Mine service lamps
MR shape lamps that have a first number symbol equal to 16 as defined in ANSI C79.1–2002, operate at 12 volts, and have a lumen output greater than or equal to 800
Other fluorescent lamps
Plant light lamps
R20 short lamps
Reflector lamps that have a first number symbol less than 16 as defined in ANSI C79.1–2002 and that do not have E26/E24, E26d, E26/50x39, E26/53x39, E29/28, E29/53x39, E39, E39d, EP39, or EX39 bases
S shape or G shape lamps that have a first number symbol less than or equal to 12.5 as defined in ANSI C79.1–2002
Sign service lamps
Silver bowl lamps
Showcase lamps
Specialty MR lamps
T shape lamps that have a first number symbol less than or equal to 8 as defined in ANSI C79.1– 2002, nominal overall length less than 12 inches, and that are not compact fluorescent lamps
Traffic signal lamps
A general service incandescent lamp is defined as a standard incandescent or halogen type lamp that is intended for general service applications and:
Has a medium screw base.
Has a lumen range of not less than 310 lumens and not more than 2,600 lumens or, in the case of a modified spectrum lamp, not less than 232 lumens and not more than 1,950 lumens.
Is capable of being operated at a voltage range at least partially within 110 and 130 volts.
This definition does not apply to 22 lamp types."
« Reply #1 on: May 20, 2023, 10:57:04 AM »
At the 'Big Teal Hourglass' we were replacing motor indicator lamps, remote/manually air actuated valves and alarm panel lamps with LED's about 10 years ago. It was their 'green contribution' while they pushed out 'methylethylbadshit' emissions and what they recovered went to the 'Thermal Oxidizer Unit' (TOU or 100MBTU burner) out into the atmosphere.
KD1SH
« Reply #2 on: May 20, 2023, 11:31:05 AM »
Most of my workshop areas are lit by LED, but I still love my big 200 watt incandescents, and buy them whenever I find them.
W1ITT
« Reply #3 on: May 20, 2023, 12:13:22 PM »
I have gone to LEDs in many applications but I still like a good old incandescent here and there.  One type to watch for is the "traffic signal" rated bulb.  They come in 100 watt and similar sizes with the standard basing that we are all familiar with.  The nice difference is that they are rated at 130 volts.  At 120 volts they last forever...or as least as close to it as I have been able to get.
As an aside, I have a lamp made with one of the old 110 volt electrical meters.  They were common in rural areas before someone decided that 220 volts would allow Ma to have an electric stove to replace the Queen Atlantic wood burner in the kitchen.  The old meter has the dials and spinning disk, but the new LEDs and "curly fries" light bulbs don't draw enough current to spin it.  So I keep a good old incandescent in there and think back to good times when there was a tube tester in most every drug store.
73 de Norm W1ITT
AL7FS
« Reply #4 on: May 20, 2023, 06:02:07 PM »
What will be best for our dim bulb testers in the future.  de AL7FS
« Reply #5 on: May 20, 2023, 06:24:27 PM »
Way back in the early 2000's, there was a push to phase out inefficient light bulbs, so the Energy Independence and Security Act of 2007 was created and signed into affect.
In fear, that I would have to live with the curly bulbs for house interior lighting going forward and I went out and bought several trays (4 six pack bulbs per tray) of 40, 60, 75, and 100 watt GE incandescent bulbs at dirt cheap prices. Since, LED bulb pricing has come way down and have proved to be more electricity cost efficient, for many uses, they can replace incandescent bulbs.
Maybe I'll start bringing  these GE bulbs to hamfests. Tag it: "The famous incandescent dummy load'
« Reply #6 on: May 20, 2023, 08:57:11 PM »
Are you sure about that Norm? I always thought that LED's had a half-life similar to like an electro-luminescence panel. When the first 120V colored LEDs came out we went on a crusade at work and replaced all the 'blue' lamps used to signify our safety showers to LEDs. What happened was the bulbs would overheat in a Class1 Div1 enclosure. The LED's worked but lasted only ~5 years. The last one I replaced was in service for 10 years and I was told it was burned out. When I went to replace, (what I thought was a bulb), I found it was one of the original LED's and it was barely visible. We ended up using 'party' CFLs. They weren't as expensive and were about the same wattage.
W1ITT
« Reply #7 on: May 21, 2023, 07:37:46 AM »
Mike...  My comment on bulb longevity was in reference to the incandescent bulbs that are 130 volt-rated.  A few years ago, Home Desperate sold them in bulk packs.  At 120 volts or so I have yet to lose one.  The absolute best I have encountered are bulbs that used to be common as side marker lights on radio towers.  They are clear thick glass, again 130 volt rated.  Once, to test ruggedness, I took one 100 feet up the tower and tossed it onto the gravel driveway.  Both envelope and filament survived.  I have a couple of those  that have served as porch lights for over 45 years.  I didn't comment on LED life as I only recently put in a few.
73 de Norm W1ITT
« Reply #8 on: May 21, 2023, 08:34:59 AM »
FBOM Norm! Those ones you dropped wouldn't be the ~75W halogens? The glass envelope on them are extremely thick and they do tend to last a long time even at rated voltage. I was just commenting about the aspect of half-life in LED lamps. I don't think people take that into consideration however if they get 5~8 years service out of one they, (as I) will happily buy another. Of course there is always this incandescent: https://blog.adafruit.com/2017/11/29/115-years-and-counting-watch-the-webcam-watching-the-worlds-longest-burning-bulb/
« Reply #9 on: May 21, 2023, 04:13:05 PM »
I converted to CFLs back in the early 2000s when the electric company was requesting their customers to switch to more efficient lighting because with computers and many other things coming online was stressing the grid here in CT.  I of course made that conversion and saw a significant decrease in KWhr usage.  Nice, I thought to myself. Electric company was losing money so they jacked up their rates to compensate for $ loss. CFLs were a bit more than the standard incandescent bulb but we offset some cost through the electric bill for a while.  Then along came LED bulbs. I did the same thing because the CFL life span was horrible and I figured them to be a fire hazard when they melt down and fail.  Now there's a HAZMAT issue with disposal.  I kept all my incandescents. In fact, bought more when the ban came along.  I swap out some LEDs to incandscents in certain rooms when winter comes along.  They produce heat. If I can keep my boiler from running more than it needs to then it's FBOM.  Home Despot LEDs are now dropping like flies.  Came across a thrift shop that had cases of LED bulbs $1.99  per.  They've been very reliable thus far.
Home of GORT. A buddy of mine named the 813 rig GORT.
His fear was when I turned it on for the first time life on earth would come to a stand still.
WD4DMZ
« Reply #10 on: May 21, 2023, 04:53:28 PM »
Standard flourescents, cfls and LED bulbs all have some flicker so I mix them up in each room and usually have an incandescent bulb on as well to soften the light. Also love the old 200W and 50/200/250 3 way bulbs. Really getting hard to find.
Rich
WD4DMZ
« Reply #11 on: May 21, 2023, 07:41:06 PM »
Years ago I acquired a vintage GE lamp like the one in the pic above. Not very bright but the filament is so thick I suspect it will last forever. I worked for GE for almost 30 years and back in 1978 they ran a batch of the lamps on original manufacturing equipment to distribute for the 100th anniversary of the company and I was fortunate to get one. So, mine is not an original from 1880 but supposedly built on the same machinery.
People do not know this but back in the early Edison era a consumer only got one bulb. If it burned out you needed to return it to get another one.
Rich
« Reply #12 on: May 23, 2023, 11:39:14 AM »
Screw in heater elements.
Henry uses them in their step start on a lot of amps and rf generators.
Just Edison based wirewoind resistors.
WP2ASS / ex KD6VXI
« Reply #13 on: May 26, 2023, 10:55:05 AM »
Not generally appreciated, but both CFLs and LED bulbs when looked at with a spectrum analyzer put out
strictly 3 monochrome colors: red, green, and blue!!
That's due to the use of rare earth phosphors.
(which if they were so darn expensive and difficult to get, you would think they would recycle??)
Whereas incandescent bulbs are actually "full spectrum" to the extent that there are no individual bands of colors.
Which in part is why these modern bulbs "don't look quite right"!!
BAH!
