February 07, 2026, 05:51:53 AM *
Author Topic: Make SURE you size your TX / Rx relay correctly.  (Read 3236 times)
« on: January 19, 2023, 06:39:17 PM »
Friend send some pics.  Thought I'd share.
He runs legal limit AM Smiley
Size your gigavac right.  This was NOT a cheap fix.
WP2ASS / ex KD6VXI
« Reply #1 on: January 19, 2023, 06:42:00 PM »
Yes.  The first pic of the inside of the relay, that's Cload next to it.  Sized appropriately.....  Peak currents are in the range above 75 amps on that cap.
WP2ASS / ex KD6VXI
KD1SH
« Reply #2 on: January 19, 2023, 07:58:31 PM »
Is he sure it wasn't a sequencing issue - hot switched it?
KD1SH
« Reply #3 on: January 19, 2023, 08:16:00 PM »
I'm using a Greenstone VC-2 in my 8877 two-holer; specs say 50 amps. It's enclosed in a Budd die-cast box, so at least the shrapnel will be contained.
« Reply #4 on: January 20, 2023, 11:21:01 AM »
I'll bet that will keep your panfish down! Wink
« Reply #5 on: January 20, 2023, 09:07:54 PM »
He uses a foot pedal for the amp and a microphone for the radio.  I do believe his amps are sequenced, I know there is more than one stage but I only saw one foot pedal.....  Didn't get into it that close / behind the scenes, other than the amplification room.
I wondered about balanced currents in the configuration used.  I would have preferred symmetric but that's a tall order for 4 vac relays that large.
WP2ASS / ex KD6VXI
KD1SH
« Reply #6 on: January 21, 2023, 09:21:18 AM »
Probably almost impossible to ensure balanced current through multiple relays; even less possible to ensure perfectly simultaneous closing/opening. I'm only using a single vac-relay for the output switching,  but I designed my sequencer to be almost painfully slow to make sure that everything is settled down before the final application of operating bias brings the tubes out of cutoff.
« Reply #7 on: January 24, 2023, 01:22:25 AM »
Handles noted.
« Reply #8 on: January 25, 2023, 04:34:40 AM »
Handles noted.
8 handles.
4 pairs.
WP2ASS / ex KD6VXI
Page created in 0.088 seconds with 18 queries.
