May 19, 2024, 08:52:05 PM *
Author Topic: Overmodulation gadget  (Read 1185 times)
WA4WAX
« on: January 16, 2023, 04:31:31 AM »
From the old days.
https://worldradiohistory.com/Archive-All-Amateur/XTAL-for-the-Amateur/XTAL-1949-02.pdf
K9MB
« Reply #1 on: January 16, 2023, 12:18:03 PM »
I used to like magic eye tubes on equipment
My 20A had one.
I like Don Chester’s Over mod sensor.
It uses an 866.
Simple and the blue glow of an 866 is cool!
http://amfone.net/Amforum/index.php?topic=27557.0
« Reply #2 on: January 20, 2023, 12:42:24 AM »
Some very old versions of 866 and 872 have an unshielded filament so that the beautiful flashing glow can be better enjoyed.
If using a standard HV recitifier of any sort, other interesting gas-filled devices can be put in series with the rectifier for a brighter or more unique flash on overmodulation.
The 0A4G octal gas triode tube is one. It usually has a clear top, looks like a fully lit eye tube when on, and is either orange or violet depending on the gas.
A small fluorescent lamp can also be used in series with the HV rectifier. No filament power required by the lamp. A phosphorless one (UV) is hard to find but a regular 4 watt (F4T5) white flourescent tube gives a bright flash that's easily seen.
A voltage bias similar to keep-alive is needed because gas tubes have a 100-150V striking voltage.
Not saying it's efficient but it is pretty and worth a few experiments.
