Check out this thread.
http://amfone.net/Amforum/index.php?topic=47699.0The title refers to W3AM’s All Filter circuit.
This circuit lowers the peak to average ratio so that modulation density is improved.
I corresponded for months in 2021 with Jim Tonne who has spent his life developing speech circuits and modulators for AM transmitters.
Jim has an active low pass software on his sight that allows one to see the ringing of a filter when driven with a very high rise time signal like clipped audio.
Unless you put this antialiasing filter after the clipper, the harmonic energy in the clipped audio plus the overshoot (ringing) will give your signal a wider bandwidth and alienate your neighbors on the band..
Here us Jim’s site:
http://tonnesoftware.com/Lots of free software and articles
http://tonnesoftware.com/appnotes/pwm/PulsewidthModulators.pdfI helped edit this paper, or rather proof read it. Jim updated not only his pwm articles but also talks about overshoot and also active filters design for “undershoot”
http://tonnesoftware.com/downloads/SpeechProcessor-As-Submitted-To-QEX.pdfHis speech processor monograph offers a complete solution for a speech system
I developed a filter under Jim’s direction that can completely eliminate the overshoot that these active low pass filters normally exhibit while amplifying square or trapezoid waves[ the worst case scenarios that we want to avoid to prevent splatter.
See the images below:
Note that the response curve is trailing off. It is necessary to get the antialiasing “undershoot” characteristic needed.
In his speech processing paper, he has as his first preamp- a filter with a peak at about 2800hz to maximize intelligibility and it gives the boost needed to make the overall response perfect.
Note that in this active filter, the capacitors are fixed and the resistors are all the same. By making the resistor values higher or lower, a cutoff that is desirable is obtained and the characteristics of the filter do not change.
I have been meaning to publish an entire summary of this work, but have not had time. This is only a portion of it. Read Jim’s articles to obtain all you need to know.
73, Mike
