April 25, 2024, 09:22:23 PM *
Author Topic: WTB: 400 Hz three-phase isolation transformer  (Read 1101 times)
WB3JOK
« on: February 28, 2022, 01:44:48 PM »
As posted in the Tech Forum, I have a rotary inverter with 115 delta, 400 Hz output at 2 KVA max. I need 115/200Y.
(So it can't be rewired to bring the neutral out, since each phase-to-neutral would be only 66 volts...)
Looking for a 3-phase 115 volt 400 Hz isolation (or dedicated delta-wye wired) transformer good for 2 KVA.
Or three separate single-phase 115 volt 400 Hz isolation transformers at 2/3 KVA each.
thanks
-Charles
