Or for 160M, tie the open wire feeders together to end feed the open wire. The 125' dipole against ground will become a capacity hat. The system will then have some desirable vertical and horizontal components for general AM coverage assuming you lay down some ground radials to work against. (system is now a vertical 'T' for 160M) Verticals work especially well on 160M when set up right.
Tom K1JJ suggested this for another thread but it has me wondering on how well this same antenna would work as a T on 40 meter and on 20 meters. I could easily do this at my camp but I would have to put out some radials which is not a problem. My 160 meter antenna does not work very well in the NE area and want to improve my signal if possible, by going to cheep & easy....My antenna is up at about 80 feet.The north end is at 355 degrees.HLR says my signal is weak compared to a real dipole that I once had up.
