EF Johnson TBolt
May 18, 2022, 04:58:34 AM *
Author Topic: EF Johnson TBolt  (Read 4559 times)
N0YXO
« on: April 07, 2021, 06:48:16 PM »
I have a Thunder bolt amp with a yl2gtm power rectifier board in it v1.o 4kv/5a. Can  any one give me any info on this product ?
not sure if it is installed correctly it was not finished installed  when I acquired the amp.
KA2PTE
KA2PTE
« Reply #1 on: April 07, 2021, 08:53:13 PM »
Sounds like something to maybe replace the original HV diode tube rectifiers it had. Got any photos?
EF Johnson RF Tube Linears
N0YXO
« Reply #2 on: April 07, 2021, 10:30:11 PM »
That is what it replaces the hi voltage rectifying tubes and caps will post pic's tomorrow
N0YXO
« Reply #3 on: April 08, 2021, 05:43:41 PM »
This is the board
W1NB
« Reply #4 on: April 08, 2021, 07:27:01 PM »
What is it that you need to know about it?
N0YXO
« Reply #5 on: April 08, 2021, 08:40:17 PM »
Just trying to get some info on it after I drew out the schematic of it I understand how it works
KA2PTE
KA2PTE
« Reply #6 on: April 08, 2021, 10:53:31 PM »
Looks like (5) 450V caps in series for 2250V, then another set in parallel probably to filter the HV....and a string of diodes to I guess do the rectification.
N0YXO
« Reply #7 on: April 08, 2021, 11:10:03 PM »
This is how it is wired
MikeKE0ZUinkcmo
« Reply #8 on: April 09, 2021, 06:52:46 AM »
Looks like it should work fine, although there are twice as many capacitors as the original PS Schematic.
Mike KE0ZU
« Reply #9 on: April 09, 2021, 11:53:38 AM »
the extra capacitors are there in case the HV bleeder goes open .... this is very conservative design
MikeKE0ZUinkcmo
« Reply #10 on: April 09, 2021, 05:19:25 PM »
If ANY bleeder goes open all the other caps are going to bleed toward ZERO or to what ever leakage current the "open" cap goes to, just before it (probably) shorts from too much EMF.
What value, and Voltage rating are the caps, something like 80-100µF @450VDC?
Mike KE0ZU
Detroit47
N8QPC on your AM dial
« Reply #11 on: April 10, 2021, 12:50:40 AM »
There is only one 8uf filter cap on a stock T bolt. It has a choke input supply. Pretty funny.
N8QPC
"We are all born ignorant, but one must work hard to remain stupid."  Benjamin Franklin
« Reply #12 on: April 10, 2021, 01:06:11 AM »
N8QPC
There was two versions of the Thunderbolt with major changes in the HV supply. There were other minor changes between the two but for this thread, the discussion is HV power supply.
See attached
« Reply #13 on: April 10, 2021, 09:30:10 AM »
Mike ... what I see from the photo are 470 uF @ 450V Nichicons ... I agree with what you say about equalizing res across each cap ... I was referring to overall HV bleed resistance which is fairly low value and high wattage ... can you say wump at turn on   Grin
N0YXO
« Reply #14 on: April 10, 2021, 02:43:15 PM »
I have what appears to be the later one of the two models. I have installed in rush limiters in the path of the plate transformer the choke is in line with the caps I received no info of what was done with it the board has been modified from original configuration from what I can tell it was close to a Tbolt 2 power supply that I have acquired print of
WA1HZK
« Reply #15 on: April 10, 2021, 04:56:37 PM »
The one thing about those amps is that they were designed to use a CB set for a driver. Anything over around 3 watts is too much. Also, the power supply is very wimpy for those tubes. Under perfect conditions you can make 125 watts of AM but no more without losing your headroom.
www.criticalradio.com
www.criticalbattery.com
www.criticaltowers.com
www.criticalresponder.com
MikeKE0ZUinkcmo
« Reply #16 on: April 11, 2021, 10:21:34 PM »
As Carl mentions there were two distinct versions.  The second version up'd the capacity from 8uF to about 13uF, but47uF I'd say is far in excess of what's needed.   Mine still has the original 8uF Oil cap but before it goes on the ops bench again, it'll get the late model fix.
Mike KE0ZU
« Reply #17 on: April 12, 2021, 12:22:05 AM »
Is Carl here?? Grin
MikeKE0ZUinkcmo
« Reply #18 on: April 12, 2021, 07:18:25 AM »
...Is Carl here??  Grin...
CARL!! Who's Carl?  Carl's not here!!
OOPS, Sorry Pete!!
Mike KE0ZU
KA2PTE
KA2PTE
« Reply #19 on: July 17, 2021, 07:14:50 PM »
In my travels I learned the last chassis made was a 1961-63 date and they upgraded R3 (350 ohms) to a non inductive array and did away with the cartridge style. Seems like its (3) 1K /14W values as per the pic.
Winds up being lower than 350 ohms (333) but I believe the grids of the 4-400A's wont mind ans perhaps some benefit attained.
The other revision is the addition of R118 (270K / 1w) which in the event the bias cable is not plugged in, provides the grids of the 4-400A's with some bias to keep them happy.
« Reply #20 on: July 17, 2021, 09:38:00 PM »
80-100mA bleed on the plate supply to get into the critical zone for the 5-25H swinger - very manly, very classic. That's what I'm talkin bout.
KA2PTE
KA2PTE
« Reply #21 on: August 06, 2021, 08:43:59 AM »
Well finally got my amp working really good after all the setbacks. Sept would have made it 3yrs
in the making. Learned alot, lots of helpful people here and on other sites made it possible.
I decided to create a support resource for the Viking Tube amps as some of them use similar parts
and they are becoming rarer all the time.
I plan to post my journey there, and future plans, and hope more owners of those kind of tube amps join to make
it more fun.
N0YXO
« Reply #22 on: August 07, 2021, 08:00:59 PM »
How do you post to the new group
« Reply #23 on: August 08, 2021, 12:58:33 AM »
Got to sign up first to groups.io
https://groups.io/register
