I have a portion of my farm that has electric fence on it. I decided to try it out as a beverage to see how better it would work before I install a proper beverage.
I see a local BC station (940khz) showing up at 1.880MHz (second harmonic) in perfect fidelity. Around S6. Even if I set the LNA to -12db it will not go away. Going back to the Inverted L I see no signal at all but noise is at S6.
Thoughts?
John
Is the electric fence wire a contiguous run, or are there splices in it? Perhaps some rectification occurring at a junction of two wire sections, causing frequency doubling to occur at one or more points in the wire run? I am sure you disconnected the fence power supply if you are using the fence as a receiving antenna!
You might also try a series L-C trap in parallel at the antenna side of the balun to block the 940 kHz fundamental, but if the cause of the 1,880 kHz signal is rectification, that may not help. An alternative might be a parallel-resonant circuit in series with the beverage, such that fundamental 940 kHz signal current is reduced, perhaps eliminating the doubling that may be occurring at a joint.
There is also the possibility that some other antenna, or structure, might have a joint that is rectifying, and re-radiating the second harmonic, now being heard in your beverage, which might not be the cause of the problem at all. Have a look at this:
http://amfone.net/Amforum/index.php?topic=26690.0
I would expect a proper beverage, constructed with new wire, proper insulation, and solid joints might not exhibit this problem.
We should ALL be fortunate enough to have the acreage necessary to implement a beverage or a rhombic. Too late in life for me to try to move, I would never get around to completing all the projects I have started.
