April 26, 2024, 06:13:18 AM *
Author Topic: VF Wireman 300 ohm window line  (Read 1887 times)
K6JEK
RF in the shack
« on: January 11, 2021, 11:14:11 PM »
Anyone  know the velocity factor for Wireman 562 300 ohm window line? The Wireman website says .91 but I vaguely remember measuring a lower figure. Steve G3TXQ (SK) measured  similar looking line at .82. But similar isn’t the same. This window line is #18, stranded copper-clad, poly-clad insulation.
Here Steve’s analysis of water on window line that includes the VF
http://karinya.net/g3txq/wet_ll/
« Reply #1 on: January 11, 2021, 11:57:15 PM »
Got a vna or swr analyzer?  If so, sweep it and compare 1/2 wave shorted readings to calculated free space readings.
K6JEK
RF in the shack
« Reply #2 on: January 12, 2021, 01:44:32 AM »
Yes. I already connected it to the antenna and wish I'd done that first. It would be a bit of a pain to chop it off, make the measurement, and put it back. That's why I was hoping someone just knew.
I'll be doing some cut and try anyway because things have a way of turning out a little different from the calculations. I'll start with .91 VF and slice my way back if necessary.
« Reply #3 on: January 12, 2021, 10:01:35 AM »
Ahh, I didn't realize you had it installed already.
I'd say take a 5 foot section and see if you can figure it out from there, but that may be counterintuitive as well....   VF seemingly changes with frequency, at least on coaxial cable.
« Reply #4 on: January 12, 2021, 12:51:31 PM »
The regular old stuff as low as 80 and the windowed stuff will get closer to 90. They advertise the DX Engineering 300 Ohm windowed stuff at 88.
