May 16, 2024, 04:04:48 PM *
Author Topic: Scope repair question - tek 454  (Read 3556 times)
w9jsw
Two shots of Whisky
« on: December 10, 2020, 07:00:14 AM »
Has anyone ever changed the graticule lamps on a Tektronics 454 scope? Mine is completely dark. I get a great clean trace but have a hard time measuring with it. This is a second hand scope that came this way to me. Looking at pics on the Tekwiki it looks like there is some sort of back light that should be there.
I love the scope and it does what I need it to do so no need to upgrade. Everything else works just fine.
John
WA2SQQ
« Reply #1 on: December 10, 2020, 04:20:25 PM »
W2AEW runs a YouTube channel, and he works for Tektronix. Reach out to him.
w9jsw
Two shots of Whisky
« Reply #2 on: December 10, 2020, 05:32:58 PM »
Think I got it sorted out. Couple of lamps on each side of the CRT at the top. Should be easy to replace. Found a source for the lamps.
Thanks guys!
John
w9jsw
Two shots of Whisky
« Reply #3 on: December 11, 2020, 04:57:42 PM »
Ran into this blog researching parts.
http://readingjimwilliams.blogspot.com/2012/02/vintage-scopes-are-better-part-1.html
http://readingjimwilliams.blogspot.com/2011/07/scope-sunday-3.html
I especially liked this one as I am a 35 yr retired IBMer... These scopes were all over the raised floor on the big data centers I visited as a kid. I actually cut my teeth on 370 storage channel micro-coding. (assy lang)
Parts source for old Tek scopes -  https://www.smcelectronics.com/tekpart.htm
« Reply #4 on: December 11, 2020, 09:01:56 PM »
When I was at NASA Langley, I worked on a lot of Tektronix equipment. They were the best manuals in the industry. Check your tech manual. They were obviously put together by a military person because they are in order the same way. A good 454 is pretty much bullet proof and was the standard analog scope until the 'sample/hold'  scopes came around.
MikeKE0ZUinkcmo
« Reply #5 on: December 13, 2020, 10:12:56 PM »
I've had a 454 for fifteen years, Paid 47 bucks for it, delivered.   It was INOP and the only thing I've ever done to it was reconnect a wire on one of the deflection plates after unpacking, maybe ten minutes.   Best 47 bucks I ever spent. Wink
My screen is dark as well, so thats going to be my next little project.
Mike KE0ZU
w8khk
« Reply #6 on: December 13, 2020, 10:17:45 PM »
Do you remember the race cars drawn on the sweep circuit schematic for the 545 series scopes?  That was a hoot!
« Reply #7 on: December 13, 2020, 11:55:36 PM »
Wow, a lot of flat topping on that waveform  Grin
w9jsw
Two shots of Whisky
« Reply #8 on: December 14, 2020, 12:37:51 AM »
Yea, that was when one fuse blew on the gfz board. We then decided that no fuses were a better idea.
