February 18, 2026, 01:56:34 AM *
Author Topic: bc610 on15MTR  (Read 5265 times)
pa3hco
« on: December 08, 2020, 04:14:50 PM »
hello
is there someone who have try the get with the bc610 on 21420?
is it possible with the tu unit ??
73 and maybe some time with the bc610 on 15MTR
pa3hco
jan
« Reply #1 on: December 08, 2020, 06:11:32 PM »
The 610 from the C model on were pretty much done above 18 MHz. I did however operate my BC-610D on 17 meters but only as a test. I never spoke to anyone on that band with it.
I don't think that a 610 would put out very much power on 21420. On 17 meters if I remember correctly, I only got about 125 watts output. One 20 meters it will put out about 150-175 watts on AM. To make it work on 21420 you would have to modify a tank coil, a tuning unit and perhaps remove some plates from the tuning capacitor?  I think you would be lucky to get 100 watts out of it on 15 meters? I have one tuning unit that someone modified for ten meters and I also have a coil modified for ten meters. I guess someone had a 610 working on ten meters but at what power?
There may be others out there who have gotten higher power out of their 610's at the normal plate voltage of 2000 volts? I would like to hear from anyone who has done so.
I hope this helps answer your question?
Terry
pa3hco
« Reply #2 on: December 09, 2020, 04:04:13 PM »
yes Terry thank you for reply but sometime you try something and as you wrote you need to do many thinks and with what result?
Page created in 0.063 seconds with 18 queries.
