December 10, 2025, 12:28:37 AM *
Author Topic: "PW" 6 watts a.m. transmitter circuit.  (Read 10115 times)
Esoteric Radio
« on: April 28, 2005, 04:04:05 PM »
If interested in homebrewing something
easy to build;
I have gotten out 250 miles, at night, on
3938 KHZ with my latest PW/QRP xmtr circuit.
here at:   http://www.angelfire.com/de/RadioAnarchy/
I was using a D104 mic,  straight into the
TDA2003 modulator, but had R7 as 470K,
and had three 10 ohm resistors paralleled for
R4 to get more audio, which was clipping.
I even plugged in my electric guitar for a test.
 Cool
N9NEO
« Reply #1 on: May 01, 2005, 09:20:20 AM »
Nice Job.
What is the TDA2003 IC chip you used?
NEO
I'd rather be anatomically correct than politically correct!
Jack-KA3ZLR-
« Reply #2 on: May 01, 2005, 09:32:12 AM »
I Like it, I'd like to see the VFO circuit used there.
« Reply #3 on: May 01, 2005, 09:43:00 AM »
Spec sheet on the TDA2003
http://www.st.com/stonline/books/pdf/docs/1449.pdf
Home of GORT.
Esoteric Radio
« Reply #4 on: May 01, 2005, 03:30:20 PM »
"What is the TDA2003 IC chip you used?"
you can use a TDA2002 or TDA2003 or
the http://www.nteinc.com/  equivalents.
NTE1288 or NTE1232
It was a common car audio amplifier IC.
"I Like it, I'd like to see the VFO circuit used there."
this xmtr is cystal controlled, but I also had my VFO
driving it.  the basic schematic is at the bottom of
the webpage.  I added a voltage regulator.
 But I came up with another VFO design I'll post,
after I re-build it.   This VFO will hopefully be able to drive a
old tube xmtr.
