November 08, 2025, 08:42:17 AM *
Pages: 1 ... 4 [5]   Go Down
Author Topic: PW Series Modulated Transmitter  (Read 60391 times)
« Reply #100 on: May 08, 2020, 01:37:41 PM »
And the finished product.
Anyway, this was a fun project and this will be my main 75m AM transmitter. I really would like to pair it with an Alpha.
Jon
Congrats on getting it built, Jon!  Mucho work and you learned a lot.
But...  "Finished Product?"   "Pair it with an Alpha?"    Not so fast.    Grin    Now the honeymoon is over and the hard work starts to see how clean it is and to optimize it.  Next: Some formal, systemized data tests.
1) Run a 50 Hz triangle audio wave thru and see how it looks, input compared to output.
2) Also, run a 50 Hz square wave thru to see how it handles it.
3) Then run a 2-tone  test to see how clean it looks up and down the band on your SDR spectrum display.
4) Do a sinewave audio sweep from 30 Hz to ~10 KHz and see how true the sinewave stays and how flat it is across the audio spectrum.  This will let you EQ it with confidence knowing that there are no band-aids covering up problems.
You may find you need some work before amplifying it thru a big amp. The 2-tone will tell a lot.    Once you get the results, there are a list of things you can look at to improve things. I can help you zero in.  (negative feedback, heavier loading, voltage stability, capacitive shunting, general IMD improvements, etc.)
Post the screen shots and data results of the tests above and put your BAs on the table, mate!
ka1tdq
« Reply #101 on: May 08, 2020, 02:03:06 PM »
True, we are never really 'finished' with any rig. There's always a tweak.
It sounds good to my ears, with the sampled audio coming directly from the antenna jack and into my headphones. But my ears aren't calibrated test equipment either.
I'm going to compare the mic input audio (goes through the 12AX7) and the line level input (bypasses 12AX7) and see what if any difference there is. I just had to order a connector to make that happen (long story).
In the meantime, I'll keep browsing Alpha's website. They're not shipping right now, by the way. Corona scared them off.
Jon
KC2ZFA
« Reply #102 on: May 08, 2020, 06:32:06 PM »
that "12AX7" you're holding looks mighty nice...can you say a little more on how you're using it ? bridged mode ? what is the driver xfmr ? the modulation xfmr ?
and from what I've read it also has a mute...you're using it ?
Peter
ka1tdq
« Reply #103 on: May 08, 2020, 07:36:01 PM »
I have a description at the end of the page:
on.radio/hamradio
I've attached the data sheet.
Jon
* AMP2X15_DS.pdf (1178.15 KB - downloaded 310 times.)
ka1tdq
« Reply #104 on: May 15, 2020, 02:37:20 PM »
Polished aluminum, who knew?
I've got some custom engraved brass labels coming too.
I had it on the air a few days ago and talked with a couple guys in Tucson.
Jon
ka1tdq
« Reply #105 on: May 30, 2020, 08:35:20 AM »
The brass labels finally came in. It's a nice finishing touch rather than using P-Touch stickers.
Jon
Pages: 1 ... 4 [5]   Go Up
