April 27, 2024, 12:35:53 AM *
Author Topic: Heathkit SB-220 Load Capacitor Issue-SOLVED  (Read 1507 times)
w3khg
« on: January 07, 2019, 03:19:31 PM »
When tuning the Load control at a certain point the control will fall due to gravity. Evidently over time the axis has become loose. Is there a way to tighten up on this?
john
w3khg
« Reply #1 on: January 07, 2019, 08:27:22 PM »
I posted this question due to having little experience with the 220 and my natural tendency is to take something apart and ask questions later. Waiting for a reply my impatience got the better of me.
On the back of the variable is a screw with a locking nut. Inside the brass screw is a ball bearing and over time brass being a soft metal had worn causing the bearing to recede inside the capsule. All it required was the screw/ball bearing to be cleaned, lubricated with grease and tightened further into the variable and the locking nut tightened. I now have very good tension on the Load Capacitor of the Heathkit SB-220.
