April 29, 2024, 05:24:21 AM *
Author Topic: Wideband noise on 75M in the Northeast - Where from?  (Read 12149 times)
« Reply #25 on: December 10, 2018, 11:13:22 PM »
Well, well...   chalk up some good detective work to the Radio Amateurs. Might be a suspect.
I just got this from Bob, WB2FOF - probably some new gov't contract:
http://micro.apitech.com/fac_statecollege.aspx
They gots plenty of cash-heat there:
http://micro.apitech.com/amplifiers
Did an RF newbie set the mouse-freq in the middle of the ham band by mistake?  Wink
It would be fun if someone called them tmw to "inquire" ...
(888) 553-7531
N1BCG
« Reply #26 on: December 11, 2018, 07:17:05 AM »
While the 75M Doomsday signal seemed to stop suddenly around 9am yesterday (someone found a note on their desk to call the FCC asap), there are new reports of a similar noise in other areas of the country.
Coordinated cable modem attacks?
Certainly an opportunity to build TDoA skills!
WA2SQQ
« Reply #27 on: December 11, 2018, 08:19:30 AM »
Did a search last night in the FCC database, and a google search for "large antenna arrays" in that area. Nothing really stands out. For that much power, it's not going to be one small antenna - it would have to be some sort of "farm". The Russia info is bogus - I'm shocked that ARRL would say that, rather than say nothing. All who did their own DF'ing should send it to Newington to provide for data for continued research.
"Laura" said she wanted the hams to assist the FCC in matters of interference - we are waiting Laura!
K3ZS
« Reply #28 on: December 11, 2018, 08:26:42 AM »
I live one mile from that company in State College.  I was not listening at the time.  From the outside it does not appear to have any large antenna system.   Now I know about this I will do snooping around the place.  Every thing around here is not part of Penn State University.
KA3EKH
« Reply #29 on: December 11, 2018, 09:23:36 AM »
I tend to think of something that would have a large antenna structure in that location and not associate it with a university. Don’t think anyone is doing that much research into HF over the horizon these days to begin with and with huge ready facilities up in Alaska why waste time in the middle of PA?
WMLK (9.275MHz) runs 25 or 50Kw in Bethel not that far from State college and there curtain antenna array and use of surplus and second hand equipment may be worth a look. Read on their web site that they had purchased a used BBC 250 Kw transmitter and recently installed that. It’s not harmonically related but who knows.
WINB (9.265MHz) is in Red Lion PA and think they are experimenting with some form of digital broadcasting on 7.325MHz this is from their web site:
A new DRM transmitter, an ASI CE-50000WS, was installed in April 2018 and is in program test at random times. The transmitter is rated at 15 kW and is using the Rhombic antenna at 062 degrees. The authorized schedule for this transmitter is: Monday-Friday 0700-0900 on 7325 kHz, 0900-1100 on 9265 kHz, 1100-1700 UTC on 15670 kHz.
Note that this is all pure speculation on my part and I have no first hand knowledge as to the quality of their engineering staffs or equipment but do have some years’ experience working with religious broadcasters and know that often there operations are often less than optimal. For that matter this can also be a AM broadcaster in the central PA region. Most AM broadcast properties are in questionable state of operations these days with FCC deregulation and budget cuts and a new generation of Broadcast engineers who are more centered on IT concerns then the operation of large directional AM patterns.
It’s not unknown for items to start to fail around the change of seasons and unless you actively check your pattern and do field readings you never know.
N1BCG
« Reply #30 on: December 11, 2018, 11:25:03 AM »
Anyone want to participate in a QRM Hunt Task Force? All that's needed to get started is the time, frequency, and location where the signal is heard. It's easier if it's picked up on a web based SDR so that others can hear it as well.
This map lists the location of SDRs that can be used for DFing https://sdr.hu/map. Press your CTRL key and roll your mouse wheel for zooming in. Click & drag works for scrolling location.
These SDRs use this URL format so you can copy and paste receiver locations into your browser without having to retune each time: http://IP address:port/?f3900.00amz10
The example shows a preset frequency of 3900kc, the AM mode, and a zoom level of '10"
The next step is to check other receivers for the same signal then couple them together for approximate analysis using the TDoA function.
« Reply #31 on: December 11, 2018, 11:51:49 AM »
On 75M, all it takes is a dipole at 50' and a 15KW class C, D, E solid state (or tube) amplifier to put out a "local" wide signal like that.   Easily built and operated by even a ham. No big ant array needed. A big antenna array like the shortwave broadcash stations use is more suited for lower angle 3,000 miles trips (like radar) and would actually be weaker than a dipole within 300 miles.  I get the impression this signal was more piss weak out farther than 300 miles, based on reports.  In comparison, look how loud some of the biggest AM guns are on 75M when conditions are good. 60+ dB over S9...
We all know how clandestine and hidden a ham station can be on 75M. A 3.9 MHz signal like we heard could easily blend into the countryside.  It may not even be API, but whoever it is, don't expect a big antenna array on 75M.
My guess is that the tester either put the rig into a dipole instead of dummy load by mistake OR he figured the hams are so inept they would never know what hit them, and the safest place to run an illegal test was within the ham band... the playground of amateurs... :-)    Little do they know that the ham bands are probably policed better than the other shortwave bands. SDR and "Toad" technology has changed the game big time.
BTW, Clark - forming a DFing "jump team" is a great idea. Being organized with a group doing their own coordinated jobs to find the perp is unbeatable.  I will contribute my own input with array DFing. I can give you a heading and distance estimate in minutes on both 75 and 40M.
N1BCG
« Reply #32 on: December 11, 2018, 12:22:26 PM »
Could all this be the result of a converted Collins 21M and a case of beer?
K3ZS
« Reply #33 on: December 11, 2018, 02:27:59 PM »
Also around one mile from me are a few large DOD labs and contractors.   Most of what they do is not known by the public.
K3ZS
« Reply #34 on: December 11, 2018, 02:34:57 PM »
I also would be interested in the rest of the story, who, what, where and why.
« Reply #35 on: December 11, 2018, 03:51:15 PM »
Agree with you guys:
Also Pretty much what I mentioned as a possible pirate on an other board earlier; Here's what a local plasma TV looks like on 75 meters, 20db attn. of course since it's in my house.
It looks and sounds like what I heard on morning of Dec. 9th.  That signal ranged weakly from 3800 to 4000 with much stronger peak ranging around 3900 kHz.
The center peak can be simply shifted by changing TV channels.
Shifting phase/time in waterfall doesn't show up locally compared to kk4yy's picture.
So, Not exactly what was show earlier in kk4yy's shot but possibly similar and easy to generate.
Edited again: Hey I think the link kkyyy provided for the kiwisdr direction finding is one
really neat dodad.!  Power to the People.  Grin
N1BCG
« Reply #36 on: December 11, 2018, 04:45:44 PM »
THAT would be fantastic!
It would be great to have a group of amateurs in various parts of the country who have experience with directional antennas such as loops and phased arrays. Being able to contact them when issues such as this arise, gathering results, and sharing that info would be invaluable.
It would also be a lot easier to get a group like that together before, rather than during, a need.
KK4YY
« Reply #37 on: December 11, 2018, 05:49:15 PM »
I've been using the online SDR TDoA DFing for the last 4 months. A little practice with it goes a long way. Propagation characteristics enter into the accuracy, so when you use it matters too.
The State College Dfing I did at about 7:30-8:30AM (local) Sunday morning. The band was fairly stable and I didn't expect much propagation from Europe, as they were in full daylight at that time. I did get some erroneous results but discarded them as outliers. Many hits clustered around State College and Harrisburg very similar to the heat image posted by N1BCG. I was actually quite surprised that it worked so well given the weird nature of that signal.
I have, in the past, DFed some AMers making nice old buzzard transmissions to within a very few miles of their location of record. SSB ops tend toward a more rapid break-in operation that makes TDoA difficult.
Practice practice practice! Wink
