May 08, 2024, 07:50:21 PM *
Author Topic: Junkbox project - 75M RF deck  (Read 14150 times)
ka1tdq
« Reply #25 on: November 06, 2018, 11:44:04 PM »
I finished wiring the oscillator and the grid tank. I'm waiting on DigiKey order #2 to finish the final and the modulator. I'm going to mount the Heising choke on the back of the modulator box so it won't be seen.  Lots of iron for 16-ish watts!
Jon
« Reply #26 on: November 07, 2018, 09:21:30 AM »
Jon
I recommend a Heising capacitor value that produces a reactance that is equal to the reactance of the Heising choke ... at the frequency where the reactance of the Heising choke is equal to the modulation resistance (3667 ohms).  I.e.
A) Modulation resistance = 3667 ohms
B) 2 x pi x 30Hz x H = 3667 ohms
H = 20 henries
C) 2 x pi x 30Hz x C = 1/(3667 ohms)
C = 1.5 uF
Jon
You need a Heising choke that can accommodate around 100mA of DC, and having an inductance value of 20H.
With 275V on the plate and 75mA of DC plate current, you would have the following:
DC input power at carrier: 21W
RF output power at carrier (assuming 80% efficiency): 16.5W
Modulation resistance:  3667ohms
Set 2 x pi x H x 30Hz = 3667 ohms => H= 19.5 henries
ka1tdq
« Reply #27 on: November 07, 2018, 01:58:14 PM »
Good formulas to note. I’ll copy and stash them.
I took a stab in the dark when I placed my DigiKey order and went with 3uF. It’ll work. I can tweak the bass and treble controls if I need to compensate.
It’s QRP AM anyway, so nobody will hear it.  Smiley
Jon
« Reply #28 on: November 07, 2018, 06:20:58 PM »
Jon
3uF will do.
Remember:
The Heising capacitor wil have a DC voltage across it of 275V.
If the modulation has a lot of low frequency content... e.g. a 30Hz sine wave... and if the modulation index is high ... e.g. 100% negative peaks... then the peak voltage across the capacitor can be as high as 2 x 275V.
I usually use two or more capacitors in series (with a 100k ohm voltage equalizing resistor across each)... to divide the voltage among them.
For example, a pair of 3uF 450WVDC capacitors in series (with voltage equalizing resistors across each of them) will have a value of 1.5uF, and a 900WVDC rating.
You definitely don’t want the Heising capacitor to fail in a way that it becomes a short circuit. If it did, it would possibly damage the modulation transformer and/or the Heising choke. A 0.15A fuse in series with the Heising capacitor would be good insurance.
ka1tdq
« Reply #29 on: November 08, 2018, 02:33:07 AM »
The 3uF capacitor has a rating of 400vdc, so I'll get another one. Then I'll be at 1.5uF anyway.
All the iron is now mounted and the weight/watts ratio is pretty high!
Jon
ka1tdq
« Reply #30 on: November 09, 2018, 07:35:54 AM »
The RF deck is done.  I'll start testing once I finish the modulator.  I'm just waiting on that 2nd 3uF cap to arrive.
In the meantime, here's a link to pass the time:
https://www.youtube.com/watch?v=CdXesX6mYUE&start_radio=1&list=RDCdXesX6mYUE
Jon
ka1tdq
« Reply #31 on: November 10, 2018, 07:27:39 PM »
I have it completed, but it's going to take a little more fine tuning.
I'm getting 5 watts output right now.  The grid tank cap is fully unmeshed and the LED isn't glowing as strongly as I think it should. I need to pull a few turns off the coil to try to bring up grid current.  This won't be easy because I used heat shrink with glue.
Also, the plate tuning cap is fully unmeshed.  I did disconnect the 47pf doorknob cap in parallel, but I'm still fully unmeshed.  There is another fixed cap in parallel, so I'll need to install a smaller value one.
Jon
ka1tdq
« Reply #32 on: November 18, 2018, 12:02:03 PM »
I kept cutting the inductor coil down for the grid tank until the capacitor came off being fully unmeshed for the highest glow on the LED.  I ended up going too far and had to add a red toroid on top to increase inductance a little bit.  It turned out to be a good thing since the big red toroid adds cosmetically to the thing.
I'm now getting 10 watts carrier.  I just need to get some wire to connect the 8 ohm output of the PA amp to the modulator to see how it sounds.
Jon
« Reply #33 on: November 18, 2018, 12:21:14 PM »
Jon
Looks great!
ka1tdq
« Reply #34 on: November 18, 2018, 07:41:39 PM »
Thanks, Stu!
I've been puttering with the modulator and the combination that works is connecting the high impedance secondary's center tap to the heising capacitor, and one end to ground.  The other end is left dangling. By doing this I get a low percentage of modulation and the audio is distorted.  I tried connecting the other end of the secondary to ground via a 2k resistor, but it wasn't happy with that.  I was thinking that I needed to balance the secondary.
...if I had only bought a single ended transformer. I should've bought a lot of other BS over the years, and life would be so much simpler now.  Oh well, no rest for the weary.  Enough complaining...
Again, this is a push-pull secondary transformer feeding a heising circuit.  Any thoughts?
Jon
ka1tdq
« Reply #35 on: November 18, 2018, 10:53:36 PM »
Ok, my bad. I didn't have it tuned properly. Once I readjusted both caps, the audio cleared right up. Monitoring the rectified RF output through my headphones, the audio sounds very good but weak. The amp I chose doesn't seem to have enough drive, but that's ok!  I'm glad that everything works.
So, another nice shelf radio to add to the collection!   Smiley
Jon
PA0NVD
« Reply #36 on: November 19, 2018, 08:29:11 AM »
Make at least a few QSO' with it Jon!!  Fun
ka1tdq
« Reply #37 on: November 19, 2018, 09:42:03 AM »
I’ll go to Las Vegas, drop it at the entrance to Carsar’s Palace and run like hell!
Jon
« Reply #38 on: November 19, 2018, 10:49:05 AM »
Jon
Use the entire secondary of the mod transformer. One end should be connected to ground, and the other end to the negative side of the Heising capacitor. Make sure the pair of capacitors is connected properly in series: at the junction beteen them... + to - . Also make sure that you have a 100kohm 1/2 watt (or larger) voltage equalizing resistor in parallel with each capacitor.
The center tap of the secondary should be floating (end insulated to prevent an accidental short to something).
ka1tdq
« Reply #39 on: November 19, 2018, 10:59:16 AM »
I didn’t want to use equalizing resistors across the caps because I didn’t want to place B+ (even at low current) across the secondary. It seems to do ok without it.
I’ll go back to using the full secondary now that I discovered my tuning error.
Jon
« Reply #40 on: November 19, 2018, 11:46:01 AM »
Jon
If you measure the DC voltage (no modulation) across each capacitor, you may be surprised at how uneven the split is if you rely on the leakage resistances of the two capacitors to be close to equal.
With a pair of 100kohm balancing resistors, the dc through the transformer secondary winding will only be 275V / 200,000 ohms = 1.375 mA.
ka1tdq
« Reply #41 on: November 19, 2018, 11:58:23 AM »
Ok, I’ll make that change.
On the other hand though, I was just testing and the plate choke for the oscillator went “puff!” I only applied power, so a short must’ve developed on the load side of it somewhere. It’s a real bother to get to, so I’m going to shelve this project for a while.
It does look cool though sitting on the shelf. 🙂
Jon
« Reply #42 on: November 19, 2018, 09:35:54 PM »
Jon
This could be a biasing problem. If you are depending on the oscillator tube to be self biasing as a result of sufficient average grid current flowing when the oscillator is oscillating ... then, if it isn’t oscillating, and if you don’t have any other bias source (e.g. a cathode resistor.... the plate current can be excessive.
ka1tdq
« Reply #43 on: November 19, 2018, 10:19:19 PM »
The tube is cutoff during receive. I have the ground lead of the cathode RF choke lifted. I ground it during transmit. It worked fine for days. There’s a lot of connections very tight under the tube socket. I’m sure something got shorted.
As an aside, I’m looking to get my big 75 meter E rig on the air again. I can now, but I’m going through an MFJ remote coax switch, and I’m guessing that it won’t handle boatloads of power. I’m finishing a homebrew version that will handle unknown megawatts of power.
It is almost winter after all. Time to get on 75.
Jon
