April 26, 2024, 09:17:32 PM *
Author Topic: Heathkit DX100 w/D104 Bassy Audio  (Read 3493 times)
W4KJP
« on: July 26, 2018, 08:09:36 PM »
Hello looking for some assistance with my Heathkit DX100.  Lately I have been getting reports that my audio is so bassy that it is unintelligible.  I am only learning about these older tube radios so any help would be appreciated.
N1BCG
« Reply #1 on: July 27, 2018, 01:31:15 PM »
A DX-100 with too many lows is a new one. Some more info would be helpful such as if the mic or transmitter has been modified. Is it an amplified or unamplified D-104? How close are you speaking to the mic?  A 6” distance will yield much less bass than close talking in many cases.
W4KJP
« Reply #2 on: July 28, 2018, 07:01:05 AM »
The only modification in the DX100 that I know of sure is that the rectifiers are solid state and the D104 is amplified.  I have used the radio for a few years now and never had any major trouble with it.  I did change out the battery in the mic but that didn't make a difference.
« Reply #3 on: July 28, 2018, 08:47:38 AM »
Even so, could there be a mismatch with the mike due to an out of spec component? Or maybe a bad part in the speech amp?
N1BCG
« Reply #4 on: July 28, 2018, 08:51:51 AM »
Do you have another microphone you could try? That would isolate the problem to either the D-104 or DX-100.
Power supply caps going bad can cause this by imposing 60Hz hum in the audio, giving the impression of bassiness and unintelligible audio. I haven't studied the audio circuit of that transmitter but it's also possible that a component has drifted out of tolerance.
Have you heard your audio either with a nearby receiver and the transmitter in a dummy load or by using an SDR where your signal is strong?
« Reply #5 on: July 28, 2018, 09:26:21 AM »
You may have lost all the highs leaving only the bottom end.
« Reply #6 on: July 28, 2018, 11:37:31 AM »
It's an amplified d104.  If they are bassy, it's typically a bad element, or a high quality operator stuffed a hand mic element into it.
My two pence worth.
W4KJP
« Reply #7 on: July 30, 2018, 07:00:28 AM »
Thanks to everyone that replied! My audio trouble ended up being isolated to my HO-10 scope I had recently put back in line.  I didn't think it would cause audio trouble but once I removed it I stated receiving good audio reports again.
