April 26, 2024, 11:06:43 PM *
Author Topic: 4X150A tube  (Read 12123 times)
W4AMV
« on: December 18, 2017, 11:26:05 AM »
Good day and Happy Holiday.
Looking at a hybrid Tx build, solid state exciter and a 4X150A output.
The tubes have been in the collection box for some time. Tarnished silver
but look like they can clean up. Heater continuity present and checking
for internal shorts.
Is there a method of bringing these tubes initially on line?
And is it necessary to use the free air flow socket?
I have read folks have used standard Loctal sockets as long as free air flow is available.
Plan is to run a single tube at 100 W with plate V at 1kV. Thanks! Alan
« Reply #1 on: December 18, 2017, 04:44:19 PM »
What are we talking here??
A linear on the output side of a low power transmitter?
Or, the final in a plate modulated rig? Or a screen modulated rig?
These tubes need airflow.
They're designed to cool via the fins.
At reduced power they need less airflow.
Regardless of the socket, IF air flows up via a pressurized chassis (or sub chassis)
there needs to be a means of directing the flow up, past the tube pins and through
not over the plate.
This is not too difficult, and all sorts of stuff can be used as a chimney, including PVC, glass,
ceramic, etc... and since it is small, pretty easy to make even with hand tools if it is PVC or
other plastic...
As far as "gettering" the tubes, I'm no expert, but I'd expect that running the filaments and
maybe bringing the tube up at low voltage, but some current, creating heat inside would be
sufficient. Check Eimac's recommendations online. And look at what people have said online
about other ceramic tubes.
I see these sockets at hamfests quite often.
Should be available online like epay too.
Probably someone here has an extra and can send you one...
But seems kind of a waste of a good high voltage tube to run it at such a low power and low
voltage to make 100 watts, plus the extra work to put air through it. A pair of 6146s will do
the same job, as will a 4D32, etc.,etc...
W4AMV
« Reply #2 on: December 18, 2017, 05:28:58 PM »
Hi Bear, thanks for the reply.
The transmitter design goal is compact size with the low level stage(s) solid state. About 5- 10 W out to drive the 4X150A to 100+ W. The mode is CW. So the power dissipation level is significantly eased. I would run these class C probably grounded grid(s) and the motivation in using them is simple... I have a bunch of them. What I don't have is the appropriate air-system socket. So I was contemplating being a bit clever here and see if fabrication of a SIMPLE socket that would provide a scheme for forcing air under the base of the tube up towards the radial fin would be possible. Again since this is CW, perhaps I can get away with an air flow scheme that is less than ideal. The built in screen bypass and all the other aspects of the special socket I would have to address.  By the way, these are not cermic but do have a glass seal which can be compromised without sufficient air flow. Apparently just lightning the tube up with no applied HV is risky without proper air flow. Although this is second hand information and not stated in the Eimac notes I have read.
« Reply #3 on: December 18, 2017, 06:09:21 PM »
Simple.  If the chassis is enclosed.
Run a piece of silicon pipe or tube from the anode to a collet on the inside of the top of the chassis. No other open holes in the top side of the chassis.
Pressurize the top of the chassis.  Now, all cool air will flow around the glass, up through the external anode, and you are almost golden.
You'll also need cooling air across the base pins. Something like a muffin fan should work.
« Reply #4 on: December 18, 2017, 11:48:53 PM »
I see those sockets on eBay quite often and for not a lot of money, they have the screen bypass built in and they also come with a ceramic chimney. I used to run the 4X150D which is the 26.5 volt filament and had no problems as long as the small blower was blown into an airtight chassis.
https://www.ebay.com/sch/i.html?_nkw=4X+150+TUBE+SOCKET&_in_kw=1&_ex_kw=&_sacat=0&_udlo=&_udhi=&_ftrt=901&_ftrv=1&_sabdlo=&_sabdhi=&_samilow=&_samihi=&_sadis=15&_stpos=12204&_sargn=-1%26saslc%3D1&_salic=1&_sop=10&_dmd=1&_ipg=200
There is one on there for $25.00 with the chimney.
« Reply #5 on: December 19, 2017, 10:08:04 AM »
Datasheet attached.
* 4X150A_D.pdf (571.96 KB - downloaded 137 times.)
W4AMV
« Reply #6 on: December 19, 2017, 01:14:02 PM »
Thanks for all the replies. The notion to try this was somewhat prompted from this article in HR Dec 75.
The idea of trying a loctal socket with suitable mounting with FREE but not forced air flow may be a stretch.
He used the appropriate socket but no forced air based on what he observed at Eimac. Alan
« Reply #7 on: December 19, 2017, 03:11:20 PM »
ok the 'golf ball' tube .... before you obligate too far be sure to hi-pot test the tubes to guard against partial vacuum ... should be good to 3 kV
KI4YAN
« Reply #8 on: December 20, 2017, 01:12:29 PM »
Also, these tubes are not designed to run in grounded grid mode-they must be grid driven.
http://ethw.org/w/images/c/c0/Eimac_tube_notes.pdf
W4AMV
« Reply #9 on: December 20, 2017, 01:54:10 PM »
Yes, I saw the Eimac note and it is another point that needs checked before I consider this approach. Despite the original authors success. One technique is to add some bias to screen and control grid. But of course, that detracts from the compactness.
The Hi-POT test is also a good idea, however, if I have a partial seal fracture that I cannot see, I expect when I bring the filament up slowly, the tube under test is going to fail pretty quick.  I am going to start there first.
« Reply #10 on: December 20, 2017, 09:01:47 PM »
I'm going to speculate that the circuit shown is "within tolerance" because of the reduced plate current and so
the screen current is similarly reduced... as compared to running the usual 2kV+ on the plates.
Still the idea of putting a screen supply in while grounding it via a capacitor has some merit.
                                _-_-
« Reply #11 on: December 20, 2017, 09:02:49 PM »
Treat it like a 4cx250.
« Reply #12 on: December 21, 2017, 10:59:25 AM »
A series of holes drilled around the socket, use a chimney and mount a fan directly under the socket on the chassis bottom.
W4AMV
« Reply #13 on: December 21, 2017, 12:53:10 PM »
Yes, that was my thought. Although if I can find the Eimac or Johnson equivalent  socket at a reasonable price, that would be nice. Applied filament V to all the tubes in the collection. No issues. Seals are fine and the heaters are operational. I had a good size muffin fan running over the tube bottom side, tube sitting on its radiator. Place a finger on the bottom side ceramic base and lightly warm. However, cut the air flow down a bit and the base can get uncomfortably  warm. How the author managed to be comfortable with no forced air is still a bit worrisome. Have to see.
« Reply #14 on: December 31, 2017, 07:44:42 PM »
I may have some spare sockets... email or PM me...
« Reply #15 on: January 01, 2018, 09:56:29 AM »
I can see using no anode cooling if the power is very low. Running it with no cooling at all on the base is may really shorten the life of the tube. The power is 6V@2.6A. They have large cathodes for their tiny size and very close spacing of the elements. The grid is extremely delicate and not designed for current, but some Eimac data shows a grid current of 1mA. As it is in the circuit where there could be grid current.
I don't disbelieve the article. It's a great practical experiment. If there were a way to find out the cathode temperature and adjust the heater current to maintain that under no-cooling conditions, it would be a possible aid. The author used a resistor to reduce the filament power probably to do that or to reduce it even below 'normal' as he said or implied. It would be interesting to know the heater voltage and current under normal circumstances and then see what it is in that circuit. A clue toward running the 4X150 without cooling. The cooler cathode would produce less current but how much is really wanted? Just if running it cool then don't 'saturate' the cathode or it might be damaged or stripped as they say?
If it's wanted to getter or hipot it, might be best to use base and anode cooling for that just to make sure it's in good shape.
Correction - data sheet with some control grid input etc. I must be having an off day!
* 4X150-A.pdf (382.44 KB - downloaded 183 times.)
« Reply #16 on: January 01, 2018, 12:01:33 PM »
It would be interesting to see the imd output of that amp.
Especially with the grid resistor kicked in.
PA0NVD
« Reply #17 on: March 23, 2018, 06:53:38 PM »
don't forget to pre-load the G2 supply, they tend to pull negative current sometimes and may provoke a run-away
Detroit47
« Reply #18 on: March 24, 2018, 03:46:07 AM »
You will smoke the tube without proper cooling period. Even with no load at all. Check out Amateur service letter 23 from Bill Orr. And I quote
" The Tube Socket
The tube socket for the external anode tube serves a triple purpose. It permits connections to be made to the elements of the tube, it serves to conduct heat away from the stem of the tube and (in some cases) the socket serves as a capacitive bypass for the screen of the tube. Complete Air-System socket assemblies for all non-coaxial based external anode tubes are available, consisting of socket and air chimney,
and these are tabulated at the end of this article. These sockets permit air to be blown axially on the base of the tube, past the base to the envelope, and then over the plate cooler. Use of other than an air socket with external anode tubes is not recommended, as tube temperatures cannot be adequately controlled. Use of a receiving-type loctal socket with 4X150A-style external anode tubes is emphatically not recommended.
Dangerously high stem temperatures will be generated from the heat of the filament unless the base structure is cooled by an air blast, as the solid construction of the simple loctal socket blocks the normal flow of air about the tube stem."
I have read all the Amateur service letters they are a great source of information as well as the GE ham tips. Just my opinion though.
Here is a link to them
http://www.rfcec.com/RFCEC/Section-3%20-%20Fundamentals%20of%20RF%20Communication-Electronics/23%20-%20RADIO%20ENGINEERING%20DATA/1979%20-%20EIMAC%20Amateur%20Service%20Newsletters%20(By%20William%20I.%20Orr%20W6SAI%20of%20EIMAC).pdf
John N8QPC
« Reply #19 on: March 24, 2018, 11:21:06 PM »
The SDP-1000L amp uses two 4X150s in AB1 with cathode drive. The grid is grounded. All inter-electrode voltages are correct including VR-tube regulated screen voltage for class AB1 500W output on the pair. It takes but a few watts drive, which is primarily consumed in the untuned input circuit.  Would the diagram be of any interest? I think I have the manual.
Fair Radio has sockets pretty cheap.
https://fairradio.com/product/4cx250s-2-zz2/
https://fairradio.com/product/4cx250s-3/
https://fairradio.com/product/4x150-t195/
https://fairradio.com/product/124-105/
W4DNR
« Reply #20 on: March 25, 2018, 11:00:33 AM »
Just Sayin......
Don't dis "grounded grid" 4CX250Bs until you try it.
Back in the 70s, I ran a quad of 4CX250B tubes in a 80/40/20 amplifier in a Bud "S-Line" copy cabinet.
Stacked 100CFM Rotrons pressurized the under chassis.
( for what it's worth that didn't work on a pair of 4CX250B tubes due to back pressure ... the Rotrons would unload with two )
I ran driven cathode with 100 ohms to ground on both grid and screen.   2200v@.9A   around 1100-1200 out with 90-100 driving.  Resting voltage was 2400+ .     Never had a tube flashover ( thankfully ).
IMD ?? Never checked, but I was in a three mile radius of lots of DXers who all had my phone number.
I did several mods over several months .... connected the grid to the cathode... no change.
I added bias and screen voltage ala the Collins 30S-1 design... the screen voltage added gain at the expense of complexity.
The Tokyo HL-1K was a similar design 500 watt out amp that used a pair of 4CX250Bs in fed cathode.
I did this when I had a unlimited supply of 250B pulls ....
Would I try this now that 250Bs are north of a Ben Franklin .. Nope.
Don W4DNR
PA0NVD
« Reply #21 on: March 25, 2018, 11:11:36 AM »
I had a Collins KWS1 that uses 2x  4CX250 in the final. Lots of info at the net about the KWS1 1 KW PEP, IMD <-35 dB. But it uses a negative feedback from the output to the cathode of the driver (curious!!) in order to linearize the final.
The finals are in grounded cathode. After 40 years it still hurts that I sold the KWS1 Cry But it was too heavy to take when I moved.
