July 28, 2026, 01:20:17 AM *
Author Topic: 809 and 812A "Old Buzzard" rigs.  (Read 2034 times)
WA4WAX
« on: July 05, 2017, 05:54:35 PM »
Think this one over:
Ditch the swinging link tank circuit.  Build a symmetric, balanced Pi-L circuit for the two push-pull tubes.  Make the output Z 50 or 100 ohms.  Put a 2000 pF blocking cap between each tube and the balanced tank.  Match the caps on a bridge or DE-6000.
Now, run out to a balanced, low pass T.  That would be 4 inductors and one cap in shunt.
Set low pass T to match antenna.
Nice scheme: Tune up AM Tx into a balanced 50 or 100 ohm load.  Tune LP T match circuit for 50 or 100 ohms at input.  Off you go!
Lots of harmonic suppression here!
Page created in 0.024 seconds with 17 queries.
