May 12, 2026, 11:28:11 PM *
Author Topic: Hammarlund HQ-180 and digital readout  (Read 5313 times)
wc4r
(c) WC4R
« on: February 19, 2017, 03:05:23 PM »
I'd like to add the ebay/Chinese digital readout to my HQ-180. But I'm not certain as to the best point to pick up the tuning frequency. My thought is to use C155/C28 just before the second converter stage.
What is the best point? (I bow to those vintage experts.)
Here is the display unit:
https://1drv.ms/f/s!AlUa4HQk6C10gd1ZnuOBHmrSrjhuUQ
« Reply #1 on: February 19, 2017, 06:11:32 PM »
The HQ-180 is a triple conversion receiver. On the lower bands, double conversion is used; on the higher bands triple conversion is used. You need the proper interface circuitry between the receiver and the display to interpolate the various oscillator and mixer frequencies to have the digital display read correctly. That's why this fellow is in business: http://www.electronicspecialtyproducts.com/dd101hu.html
wc4r
(c) WC4R
« Reply #2 on: February 19, 2017, 06:26:23 PM »
I noticed that info in the manual's circuit description Pete. Not an easy interface. May have to work up a compromise.
N3GTE
« Reply #3 on: February 19, 2017, 06:49:14 PM »
Have used that counter on my pre war HRO and it works great but it's a single conversion set. On your triple conversion set every time the conversion scheme changes from single, double, or triple the IF offset needs to change too. I don't know that you can set this counter to do more than one offset.
MikeKE0ZUinkcmo
« Reply #4 on: February 20, 2017, 07:07:31 AM »
Since those counters are so cheap, you might consider just using two of them, and picking some point to move power from one to the other when the receiver switches from double to triple conversion.
Terrell, nice transmitter.
Mike KE0ZU
N3GTE
« Reply #5 on: February 20, 2017, 08:43:07 AM »
Hi Mike,
Looks like are H-W's close in serial#as they both have the flat silk screened logo on the panel. That would indicate that it's an early run of the B,C,or D models. Somewhere around 3000 to 4000. The earlier TBS-50's and later B-D model used the cast chrome logo.
The one in the pic is a B or Jr. No modulator just cw no mic jack either just a hole for one. Don't think many of these were sold. Have only seen two over about the 30yrs I've been fooling with them. Probably geared for the "new" Novice class op's minted in the fall of '51.
Terry
N3GTE
« Reply #6 on: February 20, 2017, 11:56:00 AM »
To get back on topic you might be able to resize some of the spacers on the bandswitch to accommodate a switch wafer at the back end to do the counter switching. Did this on a TBS-50 to add in the extra loading cap for 40 and 80mtrs.
GL
Terry N3GTE
MikeKE0ZUinkcmo
« Reply #7 on: February 21, 2017, 09:32:21 AM »
It looks like you could tap "switched" power off the back side of S2G.   That's where the B+ is switched between pins 6 of both  the "455kc Gate" V18, and V3 the "first converter", ie double and triple conversion.   These things don't use much power so a 1 or  2 Watt dropping resistor for each counter would probably do the trick.
YMMV, Good Luck.
Mike
Mike KE0ZU
