I have a Valiant I that doesn't exhibit oscillation. I did note that the 0A2 does not exhibit filament in the VFO compartment. The 6AU6 VFO tube has filament. I replaced the suspect 0A2 with a known-good one and obtain the same result. Additionally, there is no oscillation with a crystal in either the C1 or C2 socket. All other tubes in the unit light up just fine. Any help with be greatly appreciated.
The OA2 does not have a filament. It will show a bluish glow when the voltage on it is high enough for it to draw current. If you don't see any glow, you may not have any B+ voltage.
