May 03, 2024, 09:35:42 AM *
Author Topic: SOLVED! powerstat 240 vac variac wiring?  (Read 3772 times)
kw4vl
« on: October 25, 2016, 11:02:38 AM »
Sorry if this is a stupid question but ..what is the proper wiring  240 vac for this variac? At one time im sure this was part of a two piece unit.
kw4vl1@gmail.com
« Reply #1 on: October 25, 2016, 01:31:32 PM »
Here's the Powerstat catalog in PDF:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwj_2fvSuPbPAhUMPz4KHfeIDTQQFggpMAA&url=http%3A%2F%2Flcweb2.loc.gov%2Fmaster%2Fmbrs%2Frecording_preservation%2Fmanuals%2FPowerstat%2520Catalog%2520P258G.pdf&usg=AFQjCNEyBQ4ksOS0YS1Y4HLl5AbC3RSSVw&sig2=KLqhoRqPkAykXA-hBmxDWw
kw4vl
« Reply #2 on: October 25, 2016, 01:42:21 PM »
Thank you for the pdf link but it doesnt show what i need or im just overlooking it..theres 5 terminals on the variac   model 1256-2S  and i cant find a specific wiring diagram anywhere.
« Reply #3 on: October 25, 2016, 04:35:09 PM »
V,
Try looking at this.....
https://www.google.com/search?q=powerstat+bp+2116&biw=1600&bih=783&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjQ3dTz3vbPAhUh7IMKHQZ9CZkQ_AUICSgE&dpr=1#imgrc=sfVpU8EjFx8PmM%3A
 Forget about your particular devise for the moment.  Look at the diagram in the above link. Note that the "common" terminal appears in both the input and output.
The winding of an auto transformer is common to the input and the output. Kinda like a taped loading coil on a vertical antenner. Anyway, you can control  the  voltage up to the 'line' voltage with one connection, or over the line voltage with the other.  You have (2) phases ( I hate the way 'they' use " phase " ) which gives you 240 V. Watt I do, for a few things, is to use a 6.3 volt transformer in place of 120V or 240V AC. I'll use the clip lead method and figure things out. ( Also, I use lots of Scotch SUPER 88 on the leads.)
I used these things in 'Lectrical' class, but its been over ~40 years so I'm a bit foggy. Not a clean answer, but you can probably figure things out.
KLC
kw4vl
« Reply #4 on: October 25, 2016, 04:38:20 PM »
Ok heres what the good people at superior electric sent me  pdf attachment for wiring  just in case it would help someone else out in the future. Thanks for the input guys! Its handy to have good people who have "been there done that" for reference.
* 1256D-2S Connection 142092_1_C.pdf (30.37 KB - downloaded 210 times.)
Page created in 0.035 seconds with 19 queries.
