March 04, 2026, 01:42:40 AM *
Author Topic: Audio distortion on the 8 FET 75 meter rig  (Read 11289 times)
ka1tdq
« on: October 22, 2016, 10:32:39 PM »
I was having a problem with the Chinese DDS VFO on my 75 meter 8 FET-er.  When switching from transmit to receive, I had to turn down both drive pots on it so that I wouldn't hear the oscillator running on the receiver.  It developed a problem in that the amplitude got stuck on full even when set to zero.  Cheap Chinese pots.  Anyway, to get around this I would just simply switch the VFO on and off.
I decided to feed over the output of a new VFO that makes things much simpler.  I just hit a button to turn off the output and I can change frequency easier.  My problem now though is that I can't hit the 150% modulation like I did before, my audio is a little distorted according to the playback of my REA modulation monitor, and my efficiency went down.
According to my calculation of efficiency under the old VFO, it was 99%.  It was too good to be true, but it was high nonetheless.  Now, my efficiency is 88%.
I know this discussion will turn to waveforms, but I do have about a 40% duty cycle going into the gates (as before) and it's tuned about the same as before.
Just a shot in the dark for all you experienced guys out there, what's my problem?  I'm also using Heising modulation.
Jon
ka1tdq
« Reply #1 on: October 22, 2016, 10:47:35 PM »
...here's the drain and gate for side 'a' at 400 watts carrier.
Jon
ka1tdq
« Reply #2 on: October 22, 2016, 11:14:01 PM »
...and here's both drains.
Jon
ka1tdq
« Reply #3 on: October 23, 2016, 12:24:52 AM »
Ah, never mind... I think I got it.
There's 10 feet of coax in between the VFO and the chassis of the transmitter.  From there, there's a little less than two feet of twisted pair feeding the IXDD bus.  I had just attached the twisted pair to the BNC center and ground.
That must've made things unhappy going from unbalanced to balanced feedline.  I put a 1.2k resistor on each BNC pin to ground and the positive peaks came back.  Yaye!  I felt inadequate there for a few hours with wimpy 100% modulation.
Jon
