May 06, 2024, 10:18:24 PM *
Author Topic: Kw match box  (Read 2037 times)
WA4JK
« on: October 21, 2016, 08:06:33 AM »
I have a question for owl to a dipole should the single wire terminal be grounded with the ground strap or should the strap be disconnected
WD8KDG
« Reply #1 on: October 21, 2016, 11:54:27 AM »
If this is the E.F.Johnson KW of which you speak.............http://bama.edebris.com/manuals/johnson/matchbox/
With mine & owl..............no jumpers to either connection. Manual states to connect single wire transmission lines to terminal designated "Single Wire". The remaining feed-thru terminal must be grounded to the ground terminal above it during operation on 80, 40, 20 meters and left ungrounded on 15, 11, & 10 meters.
There is a ground connection............stud with nut. Best connect this puppy to a ground.
YMMV
Craig,
WA4JK
« Reply #2 on: October 21, 2016, 03:32:16 PM »
Thanks that's what I thought I read in the manual but I just was not getting it.
Page created in 0.032 seconds with 18 queries.
