July 03, 2024, 04:56:03 PM *
Author Topic: Free Manuals for Appliances ?  (Read 4977 times)
0 Members and 4 Guests are viewing this topic.
« on: September 14, 2016, 06:52:58 PM »
I realize this is not ham radio related, but does anyone know of a 'BAMA' equivalent for appliances?
I have a Kenmore 80 series gas dryer that won't produce any heat, and I'm trying to troubleshoot it.  Tried the easy stuff like the ignitor, but no go.  It's good.
Any ideas about the manual (or does anyone have a schematic) ?
Thanks in advance !
Regards,  Steve
N1BCG
« Reply #1 on: September 14, 2016, 07:08:09 PM »
This website refers to a thermal fuse:
https://www.reference.com/home-garden/fuse-80-series-kenmore-dryer-bbb188230951381a
n2bc
« Reply #2 on: September 14, 2016, 07:26:41 PM »
Steve Google on the sears model number.  Go to sears.com armed with that #.
Also look here:  ($)  http://laundry.manualsonline.com/manuals/mfg/kenmore/kenmore_clothes_dryer_product_list.html
Is the igniter glowing???   They are quite fragile, if busted would be obvious.
Update:  I'm assuming it is a non-pilot type.
Be careful in there!!   Smiley
73, Bill  N2BC
« Reply #3 on: September 14, 2016, 10:21:45 PM »
Does the motor work??  I think most work the same.  Motor has to be running for the gas to work.  There is a switch circuit in the motor that turns on the gas.  Been awhile since I work on a dryer.
W1ITT
« Reply #4 on: September 15, 2016, 05:31:35 PM »
Steve..
I spotted this on the Kim Komando site.
http://www.komando.com/cool-sites/373072/free-user-manuals-and-guides-available-online
Not sure if it has what you're looking for, but the price is right.
Norm W1ITT
« Reply #5 on: September 17, 2016, 08:09:24 PM »
Well, it's AMFONE to the rescue again!  Thank you, thank you, thank you !!!    Smiley Smiley Smiley Smiley Smiley
Several of the articles referenced a thermal fuse, and described it.  So I started hunting around inside of the unit on the exhaust output, and THERE IT WAS !  Tested open with a meter, so I hooked a clip lead across the device and - voila - all worked as expected.
So, it's off to "Sears Parts Direct", which does indeed have the part in stock.  I'll be picking up the replacement tomorrow.
I never could find a service manual, but this problem was fairly straight-forward, once I knew about the existence of the part and what it does.
Thanks again - truly appreciate the help !!!!  Steve
W1JS
« Reply #6 on: September 17, 2016, 08:40:50 PM »
Steve = Clip Lead.  Grin
73 de
W1JS
Jack
No. Weare NH
« Reply #7 on: September 17, 2016, 09:36:23 PM »
Check the vent to be sure it's clear.  Thermal fuses usually open from the temperature being too high.  A clogged vent will cause the dryer to run too hot.
KC2FXE
« Reply #8 on: September 18, 2016, 08:58:15 AM »
 hello Steve:
 try this web site  www.repairclinic.com Grin
John L.Ahrens Sr.
« Reply #9 on: September 18, 2016, 04:53:22 PM »
Picked up the part, put it in and all is well.  Cleaned the vent pipe while I was at it, but there wasn't a lot of blockage anywhere.
The other possibility is that Sherrie put it on "Timed dry" on high with very little in there, and forgot.  Things get pretty hot when the clothes are completely dry.
I use the "auto sensing" mode which works quite well.
Page created in 0.09 seconds with 18 queries.
