June 09, 2024, 07:36:05 PM *
Author Topic: WTM Manual Daiwa 720B SWR Meter  (Read 3228 times)
Carl WA1KPD
« on: July 05, 2016, 08:24:14 PM »
Picked one up, and there is an off/on switch on the rear. Would be interested in a copy of the manual
WA1KPD
« Reply #1 on: July 05, 2016, 09:26:14 PM »
As requested..
http://www.radiomanual.info/schemi/ACC_instrument/Daiwa_CN-710_CN-720_user_IK8TEA.pdf&ved=0ahUKEwiSgJfq1t3NAhUN9mMKHbFkARUQFggqMAE&usg=AFQjCNFT_Eof3V5dINMeJ5uzfzx53gZoLQ&sig2=nDLTHR_NZ8sRNuvi_ScT2g
« Reply #2 on: July 05, 2016, 09:32:38 PM »
The switch in the back switches between the antenna connector and the dummy load. I believe if the rear label is there, it should say that.
See attached
Carl WA1KPD
« Reply #3 on: July 05, 2016, 09:45:28 PM »
That is the 720, which I originally listed, my bad. It is the 720B I have and there is no terminal. just a small off/on toggle switch on the rear.
Sorry for the confusion.
WA1KPD
Carl WA1KPD
« Reply #4 on: July 05, 2016, 09:55:11 PM »
All set. Automatically went to BAMA and did noit find one there. You guys jogged my mind and used Google.
No mention of the switch so I guess I will have to open her up to see what it does.
My guess now is it was user added for the lights.....
« Reply #5 on: July 05, 2016, 09:56:42 PM »
In stock form, it didn't come with lights or a toggle switch.
