May 03, 2024, 12:31:37 PM *
Author Topic: Variable Plate Cap in 2x 813 Amp. Question  (Read 1926 times)
Carl WA1KPD
« on: June 24, 2016, 06:53:14 AM »
I recently picked upatn HB 2x 813 amp based on the following circuit http://k6jca.blogspot.com/2010/06/am-transmitter-813-style-part-1-pa-deck.html It is based on the One band Killowatt Amplifiers from the ARRL Handbooks in the early 60s's.
You will note that the original construction used a Vacuum variable as the plate cap. I assume this is because it is what the constructor had available. I would like to go to a regular 1/2 turn variable and one large enough to cover 160 with the appropriate coil. (200 PF?)
I cannot find any overwhelming reason to stay with the VV, but wanted to check with the collective wisdom here.
I have also heard taht VVs do not like to be tuned around a lot as they are brittle. Is this true or an old XLYls tale?
« Reply #1 on: June 24, 2016, 04:06:48 PM »
hi Carl
found this Jennings app note:  http://www.jenningstech.com/technotes/handling.shtml
I have seen vac var caps used in motorized ant tunas.  I don't know if they were specially rated for that application.  I have seen several glass vv that have lost their vacuum, usually due to cracks in the tabulation or evacuation port
it is possible to use a lost vacuum, vacuum cap as a loading cap since the voltages there are not so high
test it with the hi-pot tester, then you will know
Carl WA1KPD
« Reply #2 on: June 24, 2016, 08:00:54 PM »
Actually I am looking for a reason to NOT go with a regular variable and I can't see that the VV adds that much. Besides I have two cool buzzardly National dials I want to use and a multi turn vacuum would take that away.
These will go either side of the window to the tubes
KB5MD
« Reply #3 on: June 24, 2016, 08:40:17 PM »
I run an 813 amp with regular variables and have never had any problems with arcing or otherwise.
Page created in 0.038 seconds with 18 queries.
