January 18, 2026, 06:44:23 AM *
Author Topic: Shove Yank Parallel  (Read 8920 times)
« on: May 03, 2016, 10:52:38 PM »
 OK,  have a single ended class E one transistor amp functioning.
Want double the power.   Eventually more,  but this is the next step:
Would I be correct in approximating push pull parallel as having a binocular core xformer from drain to drain,  with the output network after that?   I realize the core would be bigger than a standard binocular,  but ya get the gist.
If not,  what am I missing.
Thanks,  in advance.
« Reply #1 on: May 04, 2016, 01:24:57 PM »
I haven't had tremendous luck with traditional push pull and class E.  I have had very good success with single ended push-pull.  The single ended push pull approach scales VERY well, and you can parallel up MOSFETs for each of the single ended push-pull "modules", and then run the secondaries of the output transformers in series.
This may be the approach to take.  The harmonic suppression is also excellent.
Regards,  Steve
Page created in 0.066 seconds with 19 queries.
