May 16, 2024, 10:07:04 AM *
Author Topic: PTT and TX/RX timing circuit progress!  (Read 2649 times)
KJ4OLL
« on: February 14, 2016, 07:15:52 PM »
Hi,
Working on the "final" circuits for the homebrew!
Amp is a simple design, one tube only, (3CX3000A7), driven by a 32V-2.
Receiver is an R-390.
- PTT using a relay sequencing-timing circuit from Don K4KYV.
https://www.youtube.com/watch?v=ueeq4h888tc
- Vacuum relay to switch antenna between TX/RX
Discovered that the lugs on the vacuum relay are made of something that I can't solder.
Considered using the TIG machine, but...
Anyway, resorted to the lathe and a microscopic tap & Bristol screws/wrench to fabricate the connectors.
Next will be the relay & related parts to provide the PA cutoff circuit as part of the PTT operation.
Frank
KJ4OLL
« Reply #1 on: February 14, 2016, 07:45:58 PM »
Outstanding!  Nice work.  Keep the posts & pics coming. Don has a good sequencing circuit for sure
Al
KJ4OLL
« Reply #2 on: February 16, 2016, 12:45:38 PM »
In the interest of others learning from my mistakes w/ the Kilovac-Gigavac H8 vacuum relay!
Too much force on the lugs is "bad".
Fixed:
Will try again with substantially more flexible conductors.
Frank
KJ4OLL
« Reply #3 on: February 16, 2016, 01:56:58 PM »
That's sad.   Sad   Yes, zero bending moment at all times is absolutely important on these and expensive transmitting tubes
Al
KJ4OLL
« Reply #4 on: February 24, 2016, 07:21:26 PM »
Hi,
Today's progress on the PTT and PA cutoff bias relays & circuits!
Mounted one of the spare Kilovac H8 vacuum antenna relays so as to not break another one....he said optimistically
Tomorrow some actual power up testing, and possibly installation in the amp...very exciting.....
Frank
KJ4OLL
