May 03, 2024, 10:14:39 AM *
Author Topic: QRO Technologies 2500DX Amplifier...HELP...  (Read 29359 times)
W4AMV
« on: January 02, 2016, 01:56:06 AM »
Help please on repair of a QRO Technologies 2500DX AMP
Happy New Year.
Several weeks ago via the forum we received some good advice on the repair of a QRO 2500DX
AMP. A fellow ham asked for assistance to repair the HV cards, the cap bank and the diode bank card. He was operating the amp and working properly at rated power output. Then while in standby mode, with no RF excitation, a loud pop was heard, followed by smoke and fumes coming out of the HV compartment of the AMP. Several of the caps had blown seals, ruptured, and 2 of the 16 diodes were blown and shorted. Since then, we have replaced all the caps with new 105 degree C caps, put in  proper values and replaced the 2 bad diodes. Subsequently, the AMP was turned on and HV was present, 3300V (nominal is 2600V), and at that point we assumed the meter shunt, voltage divider and meter multiplication may be in error. We proceeded to allow the amp to time out, apply filament after 2 minute time out and loaded the amp to 800 W with 15 W drive. However, the plate tune and load controls seem to have NO affect. While this was in process, he heard some popping sounds, like HV arcing and shut the amp down. Now at this point, there appears to be a short somewhere taking out the 240 V lines fuses. We have been using 15 A instead of the 20 A fuses with the notion of not applying any RF excitation and trying to track down the new problem. We know the HV supply worked, there is no sign of arcing on the diode card or cap bank card, or anywhere on the chassis. The cards look perfect. All the diodes on the diode card check out perfect. If the HV xmfr secondary, 1900V AC is removed from the HV card, the fuses do not blow. Our next effort will be to remove HV from the RF cage, or simply remove plate voltage. The assumption, there is something going on in the RF deck causing the short. We have checked the plate blocking cap cold, that is no HV, and it is fine. Any other ideas and thoughts would be appreciated. We note, the HV surge protection in the form of some R in series with the HV xmfr secondary is not used in this amp. Instead an AC zero crossing detector relay in the primary is used to control in rush current and provide for a soft start for HV. If those relays are bad, is that possible, in rush current could be an issue. At this point our next step again is to remove HV from the tube plate and see if the fuses blow again. We may add discrete R's to the primary of the xmfr under the assumption the soft start relays have gone bad. Comments? In advance, THANKS! Again, the manual and schematics are on the web at:
http://www.qrotec.com/Documents/HF2500man.PDF
http://qrotec.com/Documents/HF2500circuits.PDF
Alan
« Reply #1 on: January 02, 2016, 01:02:10 PM »
making power out but tune and load controls not effective sounds like vhf parasitic oscillation...
to fix, you need to get control of this condition and reduce its intensity so that it is non-destructive ... good discussions of this n the handbooks .... basically make high voltage supply more 'rubbery' to reduce input .... this is harder when you have common fil/hv power xfmr
W4AMV
« Reply #2 on: January 02, 2016, 01:27:09 PM »
Thanks Beefus, good thought, certainly possible, and your response was echoed by another fellow. So its added to the investigate list. I'll let you know.
Tnx, Alan
« Reply #3 on: January 02, 2016, 01:46:11 PM »
3.3kv is pretty hot for  standard 3cx800.  Not so bad for the cpx version,  but the standard may be breaking down being operated 50 pct over its ratings......
That is,  assuming  shunt and metering are correct.
That said,  amp supply and qro both had cpx versions of their amps that ran on 3kv plus.   Just a hunch,  check your tube types.
(added)   I had a problem in my sb220 of a crackling sound with hv on.   Ssb (higher voltage)  louder than the lower tap for CW.   KM1H,  Carl,  sent me a few bypass caps and I replaced the one on the power supply side of the plate choke.   No more odd sounds.  That wouldn't explain yours acting like an oscillator though.
Check cathode voltage for proper bias?
W4AMV
« Reply #4 on: January 02, 2016, 02:59:07 PM »
Thanks Shane for your reply and taking time. I agree on the HV value concerns. What I cannot understand is why the HV meter on the QRO would read 3.3 kV vs. 2.6 kV unless the meter shunt or voltage divider (multiplication) network has changed value slightly.  We re built the cards with exact replacement devices. I was going to use my Triplett meter which has a 6 kV capability until I noted its accuracy on the 6 kV scale is +/- 3.3 % of FS. I read my 1200 V supply on an amp I am building, it reads 1500 V. I need to get an accurate HV DVM. In any case, there are some good trouble shooting ideas that have surfaced and will begin the hunt this week/weekend.
Tnx, Alan
« Reply #5 on: January 02, 2016, 04:27:20 PM »
Alan,
The schematic you linked to is rather hard to read since the text seems to be blurred on my little laptop screen. What I do see though is they key the final tube screen voltage, and cathode return circuit. i also see that one side of the final tube filament connects to chassis ground...
You stated that all hell broke loose when the amplifier was in standby. This means the screens are floating, as are the cathodes. So what would happen if one of the RF tubes developed a heater to cathode short? This would ground the cathodes when the screen grids are floating....it just might take off into a parasitic even though the amplifier is not keyed. Not being keyed, the input and output of the RF amplifier are without normal impedance loads, hence the tendency to sing somewhere at VHF.
Looking at the schematic, it might be good to provide a screen grid return path, maybe a 100K 5 W resistor to ground. This way, in the scenario described, given a heater to cathode short, the screen grids stay at ground, and no parasitic will occur.
In a similar scenario, I lost two 8877 from parasitics while in standby. This was in a 8877 converted amplifier I have. Just because Alpha on the Alpha 76 ground one side of the 8877 filament does not mean that is good engineering practice. My 3rd 8877 also had a heater cathode short, but did not oscillate. I just noticed the fans come on while in standby. I still use that tube, but now the filament is floating along with the cathode.
In the case here with the QRO amplifier, I wager the problem is an intermittent RF PA tube heater to cathode short along with being in standby when the screen grids are floating. A screen grid to ground resistor (maybe a 100K 5W) might prevent the next occurrence.
« Reply #6 on: January 02, 2016, 04:49:33 PM »
Alan,
Along with all the other suggestions, I pulled up the specification on the 4CX800's.  I believe that is the tubes this model amplifier uses.  The maximum plate voltage is 2500 and typical plate voltage is 2200.  So if your voltages are really up as high as your reading I would be concerned.  The question becomes, how did the voltage get that high...Measure it with a meter with known accuracy.
When the amplifier just sitting there the HV will float to the highest level.  This may give you a clue on what is breaking down under unloaded conditions on the supply.
http://qro-parts.com/images/GU-74B/4cx800a.pdf
Saying that, the amplifier obviously worked as designed so the current design should work again.  As far a inrush goes, it worked as intended and never blew the fuses so even though it may not be as good as it could be, it worked without blowing fuses.  I usually ultimately modify most of my amplifiers for better inrush control but that is just for more margin.
In my lab I am currently working on my Ten Tec Titan and that uses the hard to find and expensive 3CX800's.  RF parts has some Taylor 3CX800's but I have no clue on how good they are.  I believe my 3CX800A7's which are Eimac's are still good...!!  Be glad your using 4CX800's!
Joe-W3GMS
W4AMV
« Reply #7 on: January 02, 2016, 05:20:27 PM »
Thanks Joe and Jim. More ideas and troubleshooting tips to consider. Jim, yes sir, the system schematic is a challenge to read! I have starred at it for a 1/2 day under a magnifying lens and with my other hand re drew it on a 11x17 page of paper portions that I am interested in understanding so I can read it. Fortunate, the main sub circuits and artwork of the cards are larger. Yes, I need to put to rest the real HV value, just to be sure. Going to find a HV DVM. Again, however, I can't believe an exact rebuild of the full wave rectifier card and and the cap bank is going to go above the 1.414 x Vac( 1900V) for the xmfr in this AMP. Our first point of troubleshooting upon return to this work will be to remove the tubes or at least remove the HV from the plate choke. And see if the FUSES still get taken out. If they do not and the AMP goes through its 2 minute timer, lights the filament and screen V as well HV is present, then I would be tempted to say, we an RF circuit problem, be it tube, plate blocking cap, etc...
It is interesting to note, QRO, designed the PI match to transform down to 200 ohms, not 50 and used a 4:1 xmfr to complete the match. The 4:1 double duties as the RF safety choke.
Thanks for the additional ideas again, Jim and Joe. Particularly the mods that may prevent future failures on an expensive tube!
« Reply #8 on: January 02, 2016, 05:36:28 PM »
To narrow in on your fuse blowing issue, pull both tubes.   They should really help you narrow things down.
I would be remiss if I did not say, be very careful around the HV.  Make sure everything is off and everything is discharged prior to poking around!!
Joe-W3GMS
N8ETQ
Mort
« Reply #9 on: January 02, 2016, 05:57:05 PM »
  Yup,
    I agree with Joe, Pull the tubes and bring it up to see
what you have.  Verify bias voltage, he should be biased off
pretty hard in stby.  I would measure the "E" across the bottom
filter cap. I bet it's >450V.    Manual says 240 VAC input.. HA Ha,
your prolly hitting it with 250 +...  Find a way to lower the screen
voltage or at least check it.. I bet its high too.
   Zener diodes don't check reliably with a DMM Diode test.
A simple curent limited supply will allow you to verify they are
doing there job.. Measure across each one for expected drop.
GL and be careful
/Dan
« Reply #10 on: January 02, 2016, 06:28:43 PM »
Does the PS have any bleeder resistors or just some balancing resistors across each 450V cap??
I just looked at the schematic,  seems there is just balancing resistors, which also work as bleeders.  I would check the resistors and make certain that there is a complete circuit to ground through the bleeders.
Seems this amp works on either 200vac or 240vac input.  Any chance the main plate xfmr is connected for 200vac input??  Maybe some connections may have been moved or reconnected incorrectly during some repair work.
W4AMV
« Reply #11 on: January 02, 2016, 07:04:40 PM »
Yes, there are balance-equalizer resistors across each of the HV caps in the cap bank, they return to B- and I believe, although it is not obvious, to chassis ground. The plate meter clearly shows bleed off and I have my trusty chicken stick equipped with a 20 K poker R on the end of a 4 foot pole Smiley
Not until the Ep goes to what appears to be ZERO, do I hit the HV cap bank with my chicken stick and lay her there for about 5-10 seconds. Then I go in. I hate getting shocked and knocked on my !@#$. The amp is set and wired via the selection block shown in the schematic for 240V. I thought the same thing at first when the plate meter displayed the 3.3kV value.
In the manual is a point of interest described in the section on PLATE VOLTAGE. There is a resistor R209, which I cannot find anywhere in the schematic or artwork, that is a protection resistor connected in series with the plate voltage. If a short develops, the resistor prevents B- from rising to B+ potential. This action protects the B+ circuit components as well the 4CX800 tetrodes. Again, I can't find this R, perhaps it is mislabeled in the manual writings.
W4DNR
« Reply #12 on: January 02, 2016, 08:20:57 PM »
Build a 220vac primary "shock-absorber" using a pair of ceramic light fixtures
with two 100 watt lightbulbs ( incandescent ).  Each bulb is in series with one leg of the 220vac going to the amp.
If there is an intermittent short, the bulb(s) will brighten, but the fuses won't blow.
As always ,,, keep your hands out of the fire.
Don W4DNR
« Reply #13 on: January 04, 2016, 09:45:28 AM »
    I am still wondering about this circuit where it appears that a relay switches the amplifier screen voltage to the finals, and at the same time another contact connects the cathodes of the RF PA tubes to circuit return. The schematic is blurry, but it appears to be a dual pole SPST relay doing the switching.
    So with one side of the filament grounded, what happens if one or both RF tubes get a heater to cathode short/leakage when the screen grids (G2) are floating? Remember that in Standby the filament voltage is often high..at least this is the case in many big amplifiers.
W4AMV
« Reply #14 on: January 04, 2016, 10:08:54 AM »
Thanks for the additional tips and questions Jim and Dan. At this point we clearly need to separate HV and perhaps screen V, cathode etc...from the supply side of the unit. I am pulling together a HV DVM with 2% or better accuracy and proceed with measurements on the unloaded supply side of the unit. Need to know exactly what are the current supply readings now that the HV card (diode stack and CAP bank) has been "repaired".
« Reply #15 on: January 04, 2016, 10:48:25 AM »
     This approach works so long as the light bulb wattage is sized to the load. You want the light(s) to be dim when everything is normal, and bright during a fault. With a QRO (high power) amplifier, that might mean the bulb needs to be high wattage. Perhaps a 600 watt movie projector bulb shielded so it won't blind you should it come on full brightness. Even here, the approach might only be viable to the amplifier in standby, or when keyed with no drive. You surely don't want the 4CX800 filaments running too low.
W4DNR
« Reply #16 on: January 04, 2016, 11:36:37 AM »
Yes, you do have to size the incandescent bulbs to fit the rig.
I have a plywood board with nine 750 watt bulbs to use on three phase broadcast transmitters.
At these power levels and tripping 100 amp breakers, I'm looking for a shorted plate transformer or a faulty cable in the conduit.
On my tube ham rigs, a single 100 watt bulb seems to allow a slow ramp up of the voltages... at least slowly enough to see or hear an arc or to measure different voltages without taking out a breaker or fuse.
You need to understand what the bulb is suggesting.... A full bright may mean a shorted transformer or shorted diode stack ... a repetitive bright bulb flash could mean a HV arc ... discharging a capacitor and then cycling again.   Those are usually easy to spot or hear.    I've used a small wireless lapel microphone taped to components to isolate the sounds.     Again, just be safe with the HV interlocks defeated.
Don W4DNR
« Reply #17 on: January 04, 2016, 02:02:28 PM »
Its pretty easy to build an auxiliary DC voltage divider for measuring the HV:
Place five (5) 1 megohm, 1%, 1W* resistors in series... and then add an additional 5kohm 1/2W resistor in series with the five 1 megohm resistors.
The free end of the 5k ohm resistor must be connected to ground.
Using an ohm meter, verify that the resistance between the non-grounded end of the 5k ohm resistor, and chassis ground, is 5000 ohms. Verify that the resistance from the free end of the 1st 1 megohm resistor and ground is 5 megohms
The free end of the 1st 1 megohm resistor, should then be  connected to the HV point.
Verify, once again,  that the resistance between the non-grounded end of the 5kohm resistor and chassis ground is 5kohms.
Use this voltage divider, in conjunction with a plain vanilla multimeter to measure the voltage between chassis ground and the non-grounded end of the 5kohm resistor. This voltage will be 5000ohms/5,005,000 ohms x the high voltage being measured. I.e. 1/1000 x the high voltage
You can calibrate this voltage divider by using it to measure a DC voltage that you believe you accurately know the value of. I.e. if you use this voltage divider to measure the voltage of a voltage source whose value is known to be 153VDC, and the voltage you measure across the 5kohm resistor is 160mV, then you know that this voltage divider produces an output that is 0.160V/153V x the input voltage.
*Since the total resistance of the five 1 megohm resistors, in series, is 5 megohms, the total power dissipated by these five resistors, plus the additional 5kohm series resistor... when measuring a DC supply whose value is 3500 volts will be 3500 x 3500 /5,005,000 ohms = (approximately) 2.5 watts. Almost all of this power dissipation will be distributed, equally, among the five 1 megohm resistors. I.e. 0.5W dissipated in each of the five 1 megohm resistors.
Therefore, each of the five 1 megohm resistors should be rated (for safety) at 1 watt (or more).
Also, each of the five 1 megohm resistors will have 3500V/5 = 700V across it. For safety, do not substitute a single 5 megohm resistor for the five 1 megohm resistors in series.
W4AMV
« Reply #18 on: January 04, 2016, 02:16:32 PM »
Hi Stu. Yes, agree and I was going down that path. Smiley Then a colleague caught me by the collar and said here, use this, bring it back when your done.  Grin
« Reply #19 on: January 04, 2016, 02:37:13 PM »
that fluke hv probe is calibrated for 11meg input Z dmms .... a vom is usually 20k unless otherwise noted
W4AMV
« Reply #20 on: January 04, 2016, 03:01:47 PM »
Actually 10 Meg, but you can use other values of Zin, either add a shunt if possible or calculate the required correction for Zin values not equal to 10 Meg. It is basically a 1000:1 voltage divider, with it's Zin I believe at 1000 Meg.
W4AMV
« Reply #21 on: January 10, 2016, 03:57:09 PM »
Update...Repair of a QRO Technologies 2500DX AMP
Again, TNX for advice on the troubleshooting of this amplifier. Smiley
At this point we know what the failure is NOT, but not what IT IS!
Fuses 250V, 20A still blow, either with a healthy SNAP or a sometimes a repetitive SNAP-SNAP. WE NEVER SEE ANY ARC OR FLASH OVER!!
Tubes are pulled, HV removed from the plate choke so the RF side is totally out of the picture.
Measurement of the now unloaded HV showed about 1 kV, before the 20 A fuse goes. This is an
estimate, cause the event which takes the fuse out is pretty fast and the meter response time lags. Not an Oscope!
Ok, that said as a review, we had good HV (well it was HIGH at 3.3 kV?) from the get go after repair of the CAP bank card and the diode bank card. All the CAPS were replaced, 2 diodes were bad and replaced and that is it. We did not change out all the other diodes, however they measured fine out of circuit. We did not check out or measure all the Resistors on the cap bank card or the diode bank card. Is it possible that a HV (450V) cap is breaking down cause of un equal voltage division... hard to imagine, were at ~1 kV and we have 8 series caps.
My sense is we either have an in rush current problem (bad in rush control relay) or a dead short that is not simply on the HV card as the resistance to gnd on the HV card is not a short. That is there maybe a HIPOT short which develops and the LIGHT BULB idea in the primary may be the next best trick to find this short. Any other ideas? Again, the power xmfr is fine. Also note, WE SEE NO ARCING WHATSOEVER when the bang occurs and the fuse blows.
HV Capacitor break down? Diode(s) going short circuit, INRUSH current event??
Tnx, Alan
W4DNR
« Reply #22 on: January 10, 2016, 04:35:44 PM »
You are still getting "snaps" after disconnecting the RF section ?
I once found a 30S-1 doing something similar.... snap sounds but no flashes.
It turned out to be an arc INSIDE a ceramic HV stand-off insulator.
The insulator had a threaded hole at either end and the arc was from the ground screw and the screw that was holding the B+ to the insulator.
Don W4DNR
W4AMV
« Reply #23 on: January 10, 2016, 05:54:42 PM »
Hi Don and thanks for the reply. I understand your idea. However, the tubes are pulled, the HV from the HV B+ of the card (this is the diode bank card) connection to the RF plate choke is also removed. So this takes tube failure out of the picture, takes plate blocking cap and all of the PINET and safety choke etc... out of the picture. The problem focuses us to the three cards on the right side of the chassis, namely the HV CAP BANK, the DIODE BANK and the screen supply PCB. There is also the meter switch card as well maybe the RF I/O switch. Finally, The in rush relay (AC zero crossing detector) which feeds the primary of the HV XMFR. The XMFR is off the hook, since if the VAC (1900V) secondary is pulled from the HV diode PCB, no fuses blow. AGAIN, WE SEE NO ARCS, WE SEE NO FLASH OVERS. Something is forcing a 20 A fuse to blow with no apparent visible sign. Again, HV CAPS and HV DIODEs look pristine. I might mention that the screen supply CAPS have not been replaced, however, they look like new.
I guess what I am wrestling with is what on the diode bank card or the cap bank card could force a 20 A fuse to blow without letting the smoke out? I like the in rush current theory and maybe I need to come up with a simple experiment to check it out, like stick a nice size set of series R's in series with the HV diode bank card fed by the secondary of the HV xmfr. Easier said then done, just some effort involved but possible if you look at the schematics.
P.S. Although the schematic of the diode bank card shows transient caps (noise suppression) in // with all the diodes, .01uf, there are NONE on this card? Looks like they were never used or placed.
Tnx, for the BANDWIDTH and rambling.
W4AMV
« Reply #24 on: January 10, 2016, 06:12:00 PM »
Yes, the RF section is off line since the HV to the plate choke is removed.
Don W4DNR
